Question about Pioneer Car Audio & Video
I'm trying to run 2 12 " bmf crossfires they read 2 ohm not conected .when i run wire to them they hot 1 ohm ... then when hooked up to amp right side is good left side says on miltimeter shrt... and the both sound like they are muffeled . Take the on chip out of the left and the right one sounds really good by itself The left one shuts off Then Rollo through a champion series Pioneer GMD8601M Amplifier
Posted by Aaron Snyder on
Tommy Law
    New Friend:
  • 42 Answers
Are they dual voice coil? Are they dual 2 or dual 4 ohm? If d2 you willnot be able to run both off that amp at 1 ohm you can run 1 at 1 ohm if d4 then parallel the voice coils and the subs together to get 1 ohm.
Posted on Apr 26, 2019
5 Related Answers
Anonymous
  • 45 Answers
SOURCE: No sound from the right speaker
Check the speaker if its okay, disconnect the left side one and connect the right side one and play. If it does not then the speaker is bad.
Posted on Jan 12, 2008
Anonymous
  • 3 Answers
SOURCE: Pioneer Stereo amplifier SA-7800 sound problem
reach me at my email [email protected] for to fix pioneer amplifier 7800
Posted on Sep 11, 2008
uge44
Eugene Tetlow
  • 226 Answers
SOURCE: 500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Posted on Nov 19, 2008
romsky79
rommel dadulla
  • 822 Answers
SOURCE: need wiring diagrams from a 1994 chevy s10 to a pioneer deh-p3000
its not a big problem try another speaker from the right side. if not work. check fuse and the wire. just follow the wire where its connected. if no fuse found. the problem is in the amplifier IC. change it if speaker from right side is not burned yet. thanks.
Posted on Jun 07, 2009
Anonymous
  • 16 Answers
SOURCE: Output problem
dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
Posted on Jul 02, 2009
What's the best way to hook up my jl audio 13" w 7 sub to my jl audio 1000/1 amp
the best way? hmm. i would start off with some wire. Keep in mind that you will need to separate the positive (usually red or has a stripe or marking on it) from the negative (Black usually is the common color for this wire) and hook the up according to your amps positive and negative hook ups / terminals following your sub-woofers terminals. then depending on your sub woofers Voice coils (Duel or single voice coils) yours are duel or quad coils but i\'m sure they are duel (2 of each positive and negative equaling a total of 4 posts on each sub-woofer). figure out your amps ohm load handling and does your amp run hot (1,2 or 4 ohm stable some are even less like 0.5 or lower) i would run at a 1 or 2 ohm load as that is usually standard on 1 channel amps. make sure to check your wiring and if your not sure about ohm loads just Google wiring for sub-woofer ohm loads such as 0.5 ohm, 1 ohm, 2 ohm or 4 ohm loads. also make sure your box is not sealed do to the fact they are siht and cant produce sound like a vented / ported enclosure keep the size as big as you can fit in your car or truck the bigger the better. i had one 8\'\' sony sub pounding like a 15\'\' sub real loud . Also MDF particle board is garbage it causes port noise and absorbs water
Apr 28, 2014 | Car Audio & Video
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
How to wire a crossfire vr602 2 channel amp at 4ohm and 2ohm
I would be more worried about the amp than the speakers, those subs should handle the watts with no problem. The problem will be in the amps ability to remain working with a bridged 2 ohm load. It may not even stay on without going into protect mode with a 2 ohm load. If it does stay on then it may get really hot and shut off from the heat off of the Mosfett Transistors, or it could burn the Mosfetts from driving them too hard. Basically it's your choice, run your amp hard and gain more volume or run it with slightly less sound and have a cleaner sounding more stable amp that will stay on and have less chance of being damaged. If it's not loud enough the best thing to do is buy a different amp that better suits your needs and fits the application. In your case a 2 ohm stable Mono amp is going to be your best bet or a 4 channel amp bridged into 2 channels and run with 4 ohms on each channel. Or another exact matching amp like your 2 channel amp bridge them both and have each powering 1 of your 4 ohm subs. I used two VR mono amps to power my two 12" 4 ohm subs for a few years
Apr 03, 2013 | Crossfire VR602 Car Audio Amplifier
Crossfire vr2000d wont stop cutting out
Bad ground, possibility of some wires touching
Oct 25, 2017 | Crossfire VR2000D Car Audio Amplifier
I want to hook up a crossfire bmf 12 to my 500s. It is a dual 4 ohm speaker which config will i get the most power out of the amp. Wired at 8ohm bridged or each voice coil on a channel. That amp wont run...
You are correct, the amp will not support 2 ohms bridged. your best bet would probably be to have one voice coil on each channel. You could run them in parallel on one channel. but you will be getting the same power to each sub as if you put one on each channel. If you run them at 8 ohm bridged you will be getting less than 125 wrms per voice coil because of amp inefficiency at such a high resistance. It will sound cleaner also if you have one voice coil per channel.
Mar 09, 2011 | Rockford Fosgate Punch 500S Car Audio...
How good are crossfire p112 speakers
really good speaker. they only make 1 better than that called the bmf
Jan 03, 2010 | Crossfire P112 Car Speaker
Speaker or amp?
your running too low impedence, and yes its cuz of your sub wiring. How to wire it depends if its 2ohm dual voice coil, or 4ohm dual voice coil, so i'll explain both. O.K. first of all i hope its 4 ohm so you can get max power from your sub. If it is 4 ohm dual voice coil connect + to +, and - to - on your speaker, then to connect it to your amp, splice a wire into the wire running from + to + and connect it to your amp's + terminal. Do the same with your - wire. If its a 2 ohm dual voice coil, connect the + from one set of terminals on the speaker, to the - on the other terminal. Then to connect it to the amp, plug a wire from the open + terminal on the speaker and connect it to the + plug on the amp, and do, connect the empty - to the - on the amp. Good luck and if you have any questions don't hesitate to ask...
Sep 20, 2009 | Car Audio & Video
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
Help
one wire to pos to amp plus to speaker one. now secound speker use neg. to neg. on amp. now take a speaker wire and hook up the remaining neg. post. on the spekers. This will run them in seris like my 4000watt rms amp at a 2 ohm load. Make sur your speakers can handel the rms load of amp. If not they will blow.
Jul 19, 2008 | Car Audio & Video
No sound to speakers
is the sub dual or single?check sub first then try disconnecting all power including ground for 20min to discarge caps some amps mute if driven hard at low impedience .
Jul 01, 2007 | Hifonics BX1500D Car Audio Amplifier
Car Audio & Video Logo
44 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
