Question about Kenmore Dryers
Changed motor, thermal fuse,both thermostats but it hasn't helped. When switched to air only it still does not stay on but doesn't make the popping/crackling noise.
SOURCE: kenmore dryer model #11060932990
HAVE YOU CHECKED THE IDER ARM UNDER THE BOTTOM FRONT OF THE DRUM??????THANKS
Posted on Jul 23, 2008
SOURCE: My Carrier 58dxc is making a loud noise
If your turning on heat and the unit is knocking and blowing cold air, your compressor is having problems in heat mode, could be reversing valve. A tech is needed in your situation. Getting the prob fixed right away will save you dollars..
Posted on Dec 03, 2008
SOURCE: I have an older Kenmore
I have a kenmore elite dryer and the heat does not work in any settings... Mdel 110 c60952990.. .Checked main breaker fuse and open dryer cleaned all the unwanted lint and still no heat
Posted on Dec 22, 2008
SOURCE: loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Posted on Apr 10, 2009
SOURCE: Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
Posted on May 08, 2009
