Has the9802 been discontinued - Computers & Internet
Posted by Stuart Grace on
Has germoline ointment been discontinued ?
yes, the germolene pink ointment has been discontinued as of july 2014
Feb 02, 2015 | Germolene Ointment 27g
I have a sunbeam blender model #6094 and the blade is discontinued, is there any others that would fit this model? Thanks, Lisa
If the blade has been discontinued by Sunbeam, maybe they can suggest a substitute.
Jan 10, 2014 | Blenders
Require a replacement for Nutone discontinued motor #53709000
I'm looking for the replacement motor for Nutone 668N-part #53709000- it is discontinued. Central vacuum has a replacement buyt is out of stock. There is no new unit that fits the old opening. I have no ascess to the attic. Any ideas?
Dec 24, 2012 | Broan-NuTone Dryers
Dacor Oven model # CPS127 - part # 13158B - discontinued. How to find
More than likely your not going to be able to find a part once its been discontinued, especially if its been that way for a while, but there is an alternative though. There are companies that specialize in rebuilding control boards, etc that have been discontinued and are no longer available. I would contact a company like appliance parts depot or another major distributor because they will have the numbers you'll need to contact those companies, but remember, whatever the cost of the part was is nothing compared to the cost they charge to remake the part.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Dacor Ovens
Here in Johannesburg South Africa I need a simple easy to use handheld GPS. The best buy seems to be Garmin Nuvi 1300. But now I see it has been discontinued. Is there any disadvantage in buying it or do I...
There should be no disadvantage to buying a discontinued garmin nuvi 1300 as garmin continue to support their discontinued models. Even if you buy a new one now it will be probably discontinued next year since garmin seem to create a whole new series each year or so. Most of the garmin satnavs in use are discontinued models. When I bought mine the 1300 hadn't even been released and I have had no problems.
May 30, 2011 | Garmin GPS
Since the side kick is being discontinues will that mean I will be eligible for an upgrade?
You won't be eligible for an upgrade from your current phone unless it's already time for an upgrade. Discontinued phone production doesn't relate to discontinued support for that phone. You should still be able to go into a store for help on problems with your phone. Also; usually after phones are discontinued, there are warehouses full of them leftover so I wouldn't be too worried about it.
May 08, 2011 | T-Mobile Sidekick® 3 Cellular Phone
Need to know how to switch off hot water by combi boiler worcester bosch 240 to be able to fix leak on pipe downstairs
its the vavle 3 one in from the left its a 15mm pipe and there will be a iso vavle what you can turn with a flat point screwdriver and that will turn off the main water to the boiler these are the manual
http://www.worcester-bosch.co.uk/homeowner/literature/discontinued-boiler-literature/discontinued-gas-boiler-literature/240-bf-discontinued-december-1997-literature
Jan 23, 2011 | Heating & Cooling
Garmin 205 W has been discontinued and webupdater
I find that hard to be true. The manufactuer just came out with updates for the Nuvi 3xx and 6xx this month (Aug 09) and those models are older than your Nuvi 205W. When you mean updates are you referring to firmware or maps? Either way, even the discontinued models are still being supported with firmware & map updates.
If you are having trouble getting your unit updated, please let me know and I can help you with this.
- Jim
Aug 26, 2009 | Garmin nuvi 205W GPS Receiver
Computers & Internet Logo
16 people viewed this question
Ekse
Marvin
Marvin
