SOURCE: Select P36 not complete self diagnostic
I had same problem. Upgrading the firmware on the scanner fixed it all.
SOURCE: Kodak i260
Either the papers are sticky or there may be a stapler. Remove the stapler pins. This can happen if the papers were bound together, the small notches can imitate the stapler pin! Fan the documents and try again.
S. Mohan, Chennai, India
SOURCE: Not Scanning while Green LED lits on:
go to log foder and delete any pending work, otherwise re-install its driver and application after removing installed one.
SOURCE: I have a EPSON TM-J7100 with de power led blinking
Have you experience a paper jam prior to this problem? Open all access doors and look closely inside. Check for any tiny paper shreds that might be stuck in between the rollers or might be jamming the mechanism. Then turn off the printer and pull the power plug from the source; then power it back on.
