Humidifiers Logo
V
VIckie Allen Posted on Apr 23, 2019
My reservoir tank broke - do you have replacement parts?
Cool Mist Ultrasonic Humidifier 2065
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 • Humidifiers
Why does my humidifier holmes 1700 blows air but no water or mist?
If the water has been sitting in the reservoir for days without use, it may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
Good luck
thebqe
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 • Humidifiers
1helpful
There is not mist coming out. What should I do??
The moisture released by this (or any ultrasonic) humidifier should not be visible, so it is very possible that it is working correctly. Try filling the reservoir and marking the water level with a small piece of tape. Then run the humidifier for a few hours, and check the water level again. If the water level is below the edge of the tape, then you know it is releasing moisture into the air, and everything is working fine.
The older style of humidifiers created a mist by spinning a disk that was partly dipped into the water reservoir. They had to be refilled often, and the mist could leave water spots or dust on nearby furniture. The water level should change very slowly in your ultrasonic humidIfier compared to a misting humidifier.
7helpful
2answers
WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
No mist, but i can see a water droplet fountain on the surface
if it's a cool mist unit it will not produce any mist. now if it's a warm mist unit it should. that's normal. it is possible to replace the transducer if it is damage but you are going to have some leakage from it. but the only way to get the transducer mainly is from the manufacturer
1helpful
Replacement tank for Vicks Cool Mist V3500N
It doesn't look like they sell any replacement parts for this machine. I would call the manufacture and see if they will sell you one.
Good Luck.
Top Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Humidifier Expert? Answer questions, earn points and help others
