Question about Measuring Tools & Sensors
Outdoor sensor isn;t working - Measuring Tools & Sensors
Posted by Anca Ionescu on
I have an Acurite weather station, model 02080, and when I place the lightning sensor outdoors as it states in setup, outdoor temp is indicated. How do I set it up to work properly?
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
Apr 01, 2018 | Measuring Tools & Sensors
Sharp atomic clock SPC936
  • Remove all batteries
  • Install batteries in outdoor sensor. Allow time for outdoor sensor to begin sending temperature
  • Install batteries in indoor unit. You should see outdoor temperature displayed.
If not, the outdoor sensor or batteries may be defective
Jan 13, 2018 | Sharp Measuring Tools & Sensors
Why does outdoor temperature display only show = signs?
The outdoor sensor probably uses solar energy to charge a battery that powers the wireless transmitter. The battery may be defective or the charging circuit may have failed. The instructions that came with the station could provide some troubleshooting tips.
Nov 03, 2015 | Weather Channel WS-8500TWC-IT Wireless...
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
My indoor/outdoor temperature unit no longer will display outdoor temperatures
have you let the sensor synch while it was inside near the base unit after changing the batteries? lithium batteries work best in the cold
Aug 06, 2017 | Heating & Cooling
What happens when a knock sensor isnt working ?
If the knock sensor isn't working it isn't a real problem IF the engine isn't knocking. The sensor detects the faint pinging that comes before engine knock and sends a signal to the ECM which then begins to ****** timing until no pinging is reported by the sensor. If you do have knock and the sensor isn't working you can severely damage your engine.
Oct 14, 2012 | 1997 Infiniti.5 J30
ASU24RLF Fujitsu Air Conditioning Unit: Outdoor unit error codes E221 and E242, how do I fix this ? I need a literal translation everything I've read isn't making sense, a step by step process
E221 is an indication that the out side temperature sensor is faulty,
this could mean it's open circuit (no resistance) sensing temperature or could be it has came loose on outdoor pcb (circuit board The E242 refers to a fault code, test temperature sensor and replace and you should be problem solved
see photos attached for help in testing the sensor
Aug 20, 2012 | Heating & Cooling
My so31 ligths up but does not respond to remote
Check that the antenna isn't rubbing against the chassis as mine got rubbed thru and I think shorted the sensor. After trying playing with the left switch on the remote about 20-30 times it synced again with my chopper and I touched the open antenna wire purposely against the chasis and it would lose signal, then I removed it and it worked again. Tried that a few times so I think it's rubbing against something causing it to short out.
Jan 03, 2011 | xheli Syma S031 Outdoor RC Helicopter
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Measuring Tools & Sensors Logo
154 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
