Car Audio & Video Logo
Raymond Bice Posted on Apr 22, 2019
Reset pyle prjd903 - Pyle Car Audio & Video
Moved out of state , how do I reset old radio preset stations and add new on soundbar
The user instructions explain how to tune it in.
https://www.manua.ls/pyle/psbv200bt/manual?p=4
My Pyle Pt694bt is in protect mode how do I reset it or where do I get it repaired?
you can use the instructions in the product manual to help factory reset your device. Otherwise, you can take it to a store like Geeksquad/Bestbuy in order to get the device factory reset on your behalf. But you might want to call ahead first to ensure that location has access to the manual in order to perform the factory reset.
Thank you.
Cannot open pyle astro with pattern unlock feature. cannot remember pattern. want to reset.
You must do a factory hard reset to overcome this problem of a lost/forgotten pattern.
Will not connect to wifi
So to answer your question, there could be a number of possible problems. Some tablets around this price range are known to have issues with WiFi and/or Other wireless connections. I have looked at some reviews on Amazon and it has been a know problem for this tablet not connecting to wireless services. Most of the time you can try to restart and/or factory resetting (If you factory reset I suggest creating a backup if you have an information you need to keep). If their is a warranty I suggest either sending or taking it back to where you bought it from as it could be either a fixable problem or it could just be a "dud". I hope I was helpful!
Amazon com Customer Reviews Pyle Astro PTBL9C 9 Inch 8 GB Tablet
Pyle Astro PTBL9C 9 Inch 8 GB Tablet Pyle Astro PTBL9C 9 Inch 8 GB Tablet
How to reset your pyle Astor
If there is no reset button behind the faceplate (usually small and either black or sometimes red ) Press it and hold it down with the tip of an ink pin for at least ten seconds , when you release it it should have reset your unit. If you don't see the reset button , just disconnect the power wire (red) and 12 volt constant power (yellow) for about 10 seconds as well. That should do it ! Good luck !
Pyle astro reset factory setting
go into settings and return to default.
Im looking for the reset button on my pyle chopper series pla2200 amplifier...i was requested to look on the back of the amp or by the 'plug in fuse' near the input sockets and i still cant find it, what...
Dude, there is no breaker button, there are two 15amp fuses on the speaker connect end of the unit. Here is the link to Pyle: http://www.pyleaudio.com/manuals/PLA2200-2210-2220-4200.pdf
If it's not a blown fuse then you will need service.
2helpful
2answers
Car multi cd changer wont eject
hi
do you have any model numbers on the cd changer?
Top Pyle Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
