Question about Bosch Washing Machines
Bosch 300 series dryer is indicating E-89 error. Can you identify the problem?
Posted by steve thomas on
ray gallant
    Top Expert:
  • Bosch Master
  • 68,329 Answers
ASK Google
Posted on Apr 24, 2019
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Posted on Nov 27, 2009
Anonymous
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: Have a BOSCH 300/500 series washing machine.
The door locking mechanism has malfunctioned and/or is overheating. It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If the problem persist, you will need to replace the door lock assembly.
Posted on Nov 26, 2010
Mark
  • 39 Answers
SOURCE: Bosch vision 300 gas dryer shows error E12 evry
A friend of ours has a bosch gas dryer and she had the similar problem. She called the Bosch repairman and he came out to her house and sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Posted on Jan 19, 2011
Chris Lott
  • 3 Answers
SOURCE: dryer won't start
Had this same problem on a Nexxt 500 plus dryer. First, go outside and put up a clothes line so the wet clothes are out of the way :) LOL Anyhow to access the belt pulley fand the little switch, you have to remove the top and rear. First unplug everything. Then get a Torx T-20 driver. There are three kinds of screws so go slowly and keep them separate! Remove the top (two small screws at rear). Unplug the power cable and the ground wire. Remove most (not all!) the screws around the outer edge; several do not go thru the back panel and stay in. Finally remove all the screws in the center of the rear panel. The rear panel should left off easily. The tan box with the two thumb-tack like pins that are surrounded with springs should be easily visible at the bottom. Push the one that's out in space, away from a vertical steel piece. You should hear a little click. Reassemble (you kept the 3 kinds of screws separate, right?) and test.
Posted on Oct 09, 2011
My vision 300 dryer works but no heat ?
I would not call that working then why do you .call a service tech.
Mar 08, 2015 | Bosch Vision 300 DLX Series WTVC4300US
Is there a reset button on a bosch 300 series washing machine
turn off the power to the unit for 45 min, that resets it
Dec 05, 2012 | Bosch Nexxt 300 Series WFMC2201UC
Washing machine stopped and door opened and says E3. please help. machine is a bosch wae....
The machine identifies and indicates some operational errors through a series of beeps.E3 is also listed in that beep.the meaning of e3 is nothing but it is telling to call the service engineer.This error signal is due to Thermistor open/short.Thanks for your question.
Jun 19, 2011 | Washing Machines
How long can the duct be for Bosch dryer?
as long as u want as long as there are not allot of bends, the straighter the better.
Jan 29, 2010 | Dryers
Hello! My Bosch Nexxt series 300 washing machine is showing a E: 13 error and won't open. I have tried unplugging it but that doesn't seem to help.
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
Aug 05, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Washing Machines Logo
373 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
