Question about Watches
Accutime Flash Watch model FLH9049WM Can't open the front to even see the watch face,
Would love to know how to open the Red Flash cover that spins freely . Can't figure it out
Posted by Chris White on
ray gallant
    Top Expert:
  • Watches Master
  • 67,959 Answers
5 Related Answers
Anonymous
SOURCE: watch 3 dials inside face
so its a chrono watch i belive. well sometimes diffrent models require diffrent operations to set up the display.
Perhaps the manual can be found on the internet site of the watches brand.
Posted on Mar 18, 2008
Gene Pitts
  • 159 Answers
SOURCE: battery replacement in heart rate watch
Hello decksrnice & Guest, The battery should face 'IN' when placing in watch. The smaller size of the watch is the face. For Guest there is a flat type spring on the cover, carefully bend the spring to apply more pressure to the battery. Use a pencile eraser to clean the area the battery makes contact. If you bend the flat spring too far IT WILL BREAK.
Posted on Nov 05, 2008
Anonymous
SOURCE: i dont know how to set the time and date on my watch{arnette model ar 2041}
do you have the button on your watch named "el" its the top left one, press and hold it for 3 secs. after you can change the time. you can press the mode button to change it :)
Posted on Jan 18, 2009
SOURCE: no watch setting directions
Some of the inexpensive watches like to mimic the expensive watches and put fake dials on the face of the watch. That way you get a Breitling look alike at the price of a Timex. If there don't appear to be controls for the dials, chances are that they aren't real dials, Look closely.
Posted on Jun 15, 2009
Anonymous
  • 61 Answers
SOURCE: I DO NOT KNOW OR EVEN BEGIN TO FIGURE OUT HOW TO
Invicta watches either have screws or push pins. The one I sized yesterday had screws; it was tricky because I had to hold a flat head screwdriver on one side of the pin and then another screwdriver on the either side to unscrew it (this kept it from just spinning without loosening). If it is a push pin (you will know by looking because either a screwdriver will fit in the head or not) then you will need to get a thin steel rod about the width of a paperclip, a hammer, and a block that you can support the watch on. Push pins are pressure set and you just have to tap them out with a hammer by hitting the pin pusher/ steel rod into the pin hole to knock it out. Knock out the pins to the links you want to remove and then use a pin to resecure your watch band together.
Posted on Oct 21, 2009
Instructions for AccuTime sku #553627499
You might try contacting AccuTime.
Or, perhaps there is a similar model watch that instructions will answer the questions you have.
http://accutimewatch.com/contact-us.html
Jun 10, 2018 | Watches
How do I set the 3 dials on the women Accutime watch Model WAC5218KL
I do not find instructions for the watch at the Accutime website, via Google, nor at YouTube. I do find two contact numbers for Accutime Corporation:
toll free number: 855 222 8846
The above number appears associated with the T5 tracker model but one hopes support extends beyond such.
The below number is not toll free but is also associated with Accutime Corporation in New York.
212.686.9220
Jan 07, 2018 | The Watches
How to set & change modes?
Gem615/Garry, searched the net, the links below are what I found. You could also contact Accutime and get them to Email specific instructions. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.accutimewatch.com/contact-us.html
How To Set Accutime Watch
https://arloywarmo.files.wordpress.com/2015/11/accutime-watch-instructions.pdf
Aug 24, 2015 | ACCUTIME WATCH CORP. ACIME Round Dial...
Frenzy watch #FRZK1103 light up function no longer works, even after replacing battery. Is there a simple fix?
No simple fix, you will need a watch repair shop to fix this, but make sure you get a repair estimate, it may shock you.
Dec 07, 2014 | ACCUTIME WATCH CORP. Frenzy Ladies Watch...
No watch setting directions
Jun 14, 2009 | Watches
Watches Logo
99 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
