SOURCE: Error Code E23
Hello welcome to Fixya
E23 means
The drain pump relay on the control board has failed.
Fix: Replace control board or wire!
you can see schematics and diagrams at the site below, and order parts from them if you want.
Or call service!
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
SOURCE: E23 error code
this is a drain pump relay on the control board failure.you either need to replace the wire or the main control board
SOURCE: My Siemens WM14S791ME Frontloading washing machine
F:23 means that there is a leak into the basepan of the machine and it should be checked by a competent repair person as sson as possible, the boby pin may have jabbed a hole in somthing or more likly there is a bad seal some were on the drum.
