Question about Watches
How to link my bomgogo go fit bracelet to my phone
Posted by Neville Smith on
NOEL
    Top Expert:
  • Watches Master
  • 8,546 Answers
1 Related Answer
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I have a bracelet link
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck
Posted on Dec 21, 2008
Link removal from bracelet?
    1. Use the steps below to remove your band. You must separate the Link Bracelet into two pieces before removing the band from your Apple Watch. While removing the band, don't force the band or twist it. Use the steps below to avoid damaging the band or clasp.Jun 19, 2015
      Remove the Link Bracelet on your Apple Watch - Apple ...
      https://support.apple.com/en-us/HT204831 Apple Inc.
    Feedback
  1. How to resize or remove links from your Magnetic Bracelet ...
Jan 01, 2016 | Watches
I need to get a spare bracelet link for a Seiko SMA075. Where is it available? Thank you.
You can get bracelet links for Seiko watches at Coserv, Seiko's main repair center located in New Jersey. The phone number to Coserv is 1-800-722-4452. If for some reason your links are discontinued occasionally a local watch repairman will have spare links! I hope this helps!
Sep 14, 2011 | Seiko SMA075 Wrist Watch
Caravelle by bulova 43b17how to adjust Stainless steel bracelet
To remove some links: If you don't have special tool, at least you have to have something really hard and thin (like the pin you use to post notes on the cork board). Put that pin in to the tiny hole between links where the bracelet pin is and then press/push it forward (follow arrow direction as shown on the inside of the bracelet links.) When the bracelet pin comes out at one end, pull it out of that end totally.
After removing one links, connect the two links next to each other by placing the bracelet pin back into the hole and push it to the other end.
To add some links: You have to have spare links and do the same way with the pin to attach more links.
Feb 17, 2011 | Watches
I need to buy new bracelet
mcdevito75 here, BEST BET for your Ebel watch, look for a small watch repair shop in your area, to order a new bracelet.
Jul 13, 2010 | Ebel Type E Stainless Steel Rubber Strap...
How to adjust expandable bracelet pleaseI would like to remove links to make it smaller.
Check the sides of a bracelet. You will notice that the upper band metal is flipped over the bracelet side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When links are out, take the staples and drive them back into the bracelet joining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over the bracelet sides.
Good luck.
Jul 29, 2009 | Casio Watches
Self-adjustable bracelet watch
Good luck.
Rate me, please.
Mar 19, 2009 | Timex 2J611 Watch
I have a bracelet link bracelet expansion bracelet watch I need to remove some links
Good luck
Dec 21, 2008 | Timex 2J611 Watch
Tissot T-Touch T33.7.788.51 Bracelet replacement
Sounds like it's broken @ a factory sealed link (non servicable). Local jeweller should be able to order & fit you a new one
Feb 19, 2008 | Tissot T-Touch T33759851
Fossil watch me1001 bracelet adjustment
I took mine to a watch store, and had them remove a link.
Dec 08, 2007 | Watches
My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Jul 28, 2007 | Tag Heuer Link CJF2114
Watches Logo
90 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
