Replaced carb, air filter, and spark plug. Started right up but running fast and loud. What have I done?
Its the govenor. Don't run it till you fix. Carb spring goes to freely pivoting vane around flywheel or spring goes to a a bracket
Posted on Apr 21, 2019
SOURCE: have a lawnboy 10685,changed spark
you need to find out whether it is a fuel or ignition problem, I might suggest that when it quits pull spark plug and ground it to head and pull the rope like you are starting and see if you have spark, if no spark, then I would say your coil is bad, once it gets warm, it quits.....good luck
Posted on Aug 25, 2011
Testimonial: "thanks for the ifo will give it a try tomorrow."
