Question about Refrigerators
Where is the temperature control for Kenmore Elite Coldspot Smartsense 106.41163310?
Posted by Ann Fitts on
geob91
    Passionate:
    Visited the website for 10 consecutive days.
  • Refrigerators Expert
  • 128 Answers
The temp controls can be accessed from the front panel. Factory preset should be 37'f for the fridge and 0'f for the freezer. If you hold the temp button for 3 seconds it will let you see, and adjust both sections.
Are you having an issue? Or just want to see what the settings are?
Posted on Apr 22, 2019
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: Kenmore side by side coldspot, model 5687
I'm not trying to be a smart ***,but a lower temperature setting would make it colder.Try using a higher temperature setting.If this was just a poor choice of words you may need to replace your thermostat.
Posted on Jun 18, 2009
Bothcoasts
Ron Lucas
  • 10 Answers
SOURCE: kenmore elite refrigerator temperature controls
I am sorry I am not a top refrigerator expert. It sounds like there is a way to reset that. You most likely hold down two buttons for a period of a few seconds.
Sorry I don't have the time to search the net for that particular manual or way to reset that board. If you have no luck by tomorrow try me then.
Posted on Jul 27, 2009
Richie_asg1
Richard Perkins
  • 1036 Answers
SOURCE: I have a Kenmore Elite
Check the freezer temperature with a separate fridge thermometer.
It could be a fault with the sensor in the freezer - which can be replaced.
Posted on Dec 27, 2010
muffteck
Frank England
  • 202 Answers
SOURCE: Kenmore Elite Coldspot Refrigerator. Ice
ck water supply see if trays full first
Posted on Mar 16, 2011
Andy Turner
  • 910 Answers
SOURCE: Kenmore elite upright freezer, model
OFF indicates that the Temperature Control is switched Off.
Pressing the Up or Down Buttons should change the display back to the Temperature Display and allow you to set the required Temperature.
Posted on Jun 13, 2011
I have a model # 955031636 Kenmore coldspot indoor light comes on nothing else,possible causes?
The inside light confirms power is getting to the refrigerator. You may have to operate a control such as the temperature setting to start operation.
Apr 18, 2016 | Kenmore Refrigerators
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
How do I replace the defrost control board on a kenmore elite coldspot 106 ?
The board is usually in the fridge side up by the controls and usually is hidden. If you take your model number and go to apdepot.com or partselect.com you can get an illustrated breakdown of the machine and where each part is
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Kenmore Refrigerators
I have a Kenmore Elite Coldspot Side - By - Side Refrigerator, Model # 106.55612400 which is nlonger making ice. It does dispense water. My freezer temperature setting shows 0 degrees. Is this the problem...
Dec 27, 2010 | Refrigerators
Kenmore coldspot model 106: top freezer leaks water slowly into botton refrigerator. how do I repair it?
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Dec 19, 2010 | Kenmore Refrigerators
Kenmore elite coldspot 106.55606400 --fridge not cold enough --
37 is the atual temperature that your trying to acheive. so to make it colder you would go down to 36 which is one degree cooler. hope that helps. thx peyton
Jan 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
643 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
