Question about Orion Televison & Video
Set up and connections for Orion VR0220 - Orion Televison & Video
Posted by Gene Gold on
How do I download Netflix on my Orion TV?
Is it a Smart TV? It has to be, then you press the Smart Button on the Remote and go to Apps, download Netflix which you may find is ready installed. Then set up your account details.
Sep 18, 2014 | Orion Televison & Video
Digital programing
By the look of it you would need to connect a digital set box to it to record any TV programs, seeing that most countries are switching off or have switched off analogue TV. The video would then pass any signal it had recorded via a scart lead to any TV with one of those sockets.
Feb 11, 2014 | Orion VR0220 VCR
Vcr only plays sound, what's wrong ?
Try cleaning the video head with Servisol Video 40 see image:
Feb 26, 2010 | Orion VR0220 VCR
Orion VCR 213 will not record with converter box
The chain of cabling that you have should go like this; First in line should be the wall supplying the cable box. Then, the cable box connects to the VCR, then the out of the VCR should go to the TV. Select whatever channel you desire, make sure that the VCR is on Channel 3 or 4, (Whichever the back of the cable box is set) then select 3,4 or line/AUX to see the results....accordianman
Dec 12, 2008 | Orion VR213 VHS VCR
Vcr picture problem
clean the heads. check out my tip
Nov 02, 2008 | Orion VR213 VHS VCR
Many channels do not come in. I feel it needs reprograming. I have cable .
Make sure that the set is in the correct mode. It sounds like the set is expecting TV signals from an antenna rather than cable. The cable channel assignments are different. Place the set into CABLE mode and autoprogram the set. That should resolve the problem.
Dan
Jul 07, 2008 | Orion1934 19" TV
Orion FTDV 2004 Dead Set
Question, when I clicked on this I clicked on a problem for a Sony KV27S10 but your text say's Orion, is it a Sony or a Orion?
Aug 18, 2007 | Sony KV-27S10 27" TV
How to set clock on Orion VCR VR0419
Most late VCRs require the remote box to set the clock, timed recording etc. Assuming you have the Orion remote, it should have a programming or menu button, and the function you need can be selected from a list of options. If the remote is an aftermarket unit (non-Orion), it must have the capability to do the advanced setup (clock set etc.). Many aftermarket remotes only do basic channel selection, and tape functions (play, rewind, stop, etc.).
Apr 24, 2007 | Orion VR0419 VHS VCR
Televison & Video Logo
50 people viewed this question
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
