Question about Miele Dishwashers
SOURCE: Locking clamp for non-return valve
It will have to be ordered from Miele
Posted on Jan 09, 2009
SOURCE: motor runs contiuously. non return valve pipe and
Which pump model is this? Could be that the pressure chamber may be stuck on the on position. There is a rubber membrane at the bottom of the pressure chamber which turns the unit on and off. The membrane may be warped, a piece of solid may be stuck at the bottom or the micro switch can be stuck on the on position.
Posted on Jul 27, 2010
SOURCE: Miele G892SCB intake/drain light on.
Yes. 1 800 843 7231. follow the prompts to get to the parts department. have your model and serial number handy. They will get you the correct part. If you have any problems getting it in, or it doesnt solve your problem, repost. I will keep an eye out.
Posted on Nov 21, 2010
Testimonial: "thank you, you have been very helpful and have probasbly saved us a new dishwasher."
SOURCE: miele dishwasher drainage
there will allways be some water under the filter. when you remove the non return valve, there should be a rush of water coming back into the sump from the drain hose. if not, the seals in the non return valve are bad and you need a new part. they are not that expensive. switch to an appropriate detergent such as miele or finish all in one powerball tabs and the new part will last much longer. cascade and other brands are eating the seals in dishwashers faster than i can replace them.
Posted on Jun 27, 2012
