Question about KitchenAid Dishwashers
How do I reset KitchenAid KUDE40FXSS?
Pressing High Temp Scrub/Heat Dry repeatedly does not reset.
Posted by Glen Mustard on
5 Related Answers
Anonymous
SOURCE: Dishwasher will not start
turn unit off at the breaker and leave off for 10 mins before turning back on,  if this does not reset the unit, then your control board is probably bad or the heating element could be going bad.  call a repair man for service
Posted on Oct 12, 2007
Anonymous
SOURCE: Kenmore Elite 8269645
I have this model, but not this problem (my impeller motor seems to have burned out). Anyway, try pressing Hi Temp Scrub, Air Dry, Sani Rinse, Air Dry, in that order and see what happens. Mine appears to reset and run through a set of warm-up tests.
Posted on Jul 27, 2008
Anonymous
  • 70 Answers
SOURCE: Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
Posted on Feb 19, 2009
SolutionGuy
Tracy Farrell
  • 331 Answers
SOURCE: Kitchenaid dishwasher kudi24sewhi stops after filling
Hi canchild,
By your description this sounds as though the machine control board has failed. But you should test it first.
Go to Home Depot or Lowe's and pick up a non-contact voltage tester, like this one. It's a tool that you'll use more often than you think for this project and others around the home,
WARNING---> THESE TESTS REQUIRE YOU TO HAVE POWER ON! AVOID ANY EXPOSED WIRING OR ELECTRICAL TERMINALS THROUGHOUT THE TEST PHASE!!!
Now remove the 4 screws holding the kick panel to access the lower section of your dishwasher. Set the dishwasher to run a normal load and start it.
The sequence is the washer will send power to the water valve first, test this with your new tool... it should light up if the tub is empty. If it's already full, power will not be applied to the valve. When the tub is full, the board will send power to the main wash motor in about 1-2 minutes. Use your Voltstick on the main motor harness. If the board is good, your stick will light up.
Now hit "Cancel"... this should activate the drain pump (it's on the right, connected to the pump sump and has 2 wires feeding it). Again, test with the Voltstick.
NOTE---> Your Voltstick may give you false positives... avoid this by singling out individual wires to test. DON'T TEST "WIRE BUNDLES".
These tests will confirm whether or not the board is sending power to the components in question. If you have power? The components have failed OR the wiring to the components have become loose, broken or disconnected.
If you aren't getting power to the components, your board has failed and will need a replacement. The part number for it is 9743448 and lists for about $160.
Hope this helps!
SG
Posted on Apr 05, 2009
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: I have a Kenmore Elite ULTRA WASH Dishwasher
Hi
This issue appears due to stuck keys on control keypad or due to moisture/shorted connections on the keypad. Sometimes this appears when the door is not closed or door lock switch is failing. Turn off the power to dishwasher, unplug the power cable from outlet or shut off the breaker. Use a multimeter and make sure that the connection to door switch assembly are fine, also check the continuity of the door swiches (when closed). If continuity is present you would need to check the connections to the keypad. Try disconnecting the P1 connector(connects keypad to control board) and then reconnecting it, check if the problem is still present. Replace the keypad if the problem still appears. Please check the below pictures, they might help you--
Link 1 (Door Switch)
Link 2 (Keypad)
Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 10, 2011
Reset kenmore dishwasher
The most common "reset" key sequences are:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry).
On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jun 15, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
My KUDS011JBSO undercounter dishwasher is blinking the normal wash light. What do I need to look for to fix this?
Hi
If light is blinking then it may be an issue with heater circuit, door switch or the thermal fuse, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the thermal fuse located on the control or the door switch that is bad and should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | KitchenAid Dishwashers
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light is flashing. Dishwasher will not start.
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 29, 2011 | Whirlpool Dishwashers
Clean light "green" flashes 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or high temp wash-heated dry-high temp wash-heated dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 29, 2011 | Dishwashers
Whirlpool gold quiet 3 dishwasher flashing clean light nothing works i had to push 2 button and cant remember code to reset unit
Hi
Daniel
Aug 28, 2011 | Whirlpool Dishwashers
Clean button flashing, how do you reset?
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 16, 2011 | Kenmore Dishwashers
I have a whirlpool quite porter the led light blinks 7 times then keeps repeating
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Feb 13, 2011 | Whirlpool Dishwashers
We can't get it to cycle.... the green light next to 'clean' is flashing on the panel - can't get it to stop flashing and run??
Found it; High temp scrub--Energy saver dry---High temp scrub---Energy saver dry--press start, close door ,wait for it to reset,open door press cancel and you are ready to go.
Jul 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The clean light is blinking
try pressing "high temp scrub" button then " air dry" button then "high temp scrub" then "air dry" all in sequence very quickly. This just worked for me. Same problem.
Working now.
Jan 30, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Dishwashers Logo
273 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
