Question about Car Audio & Video
How do I reset HU-850 CD player? - Car Audio & Video
Posted by Michael Flannagan on
3 Related Answers
Anonymous
  • 54 Answers
SOURCE: HU 850 CD stuck in player
One thing about Volvo CD player/changers...they tend to not like burned CDs and even more, burned CDs with labels on them.
I'd suggest against trying to get it out yourself.
You can get it replaced and the dealership should have a form so you can get your CDs sent back.
Posted on Aug 15, 2008
guerrero_ros
Rosie Gee
  • 113 Answers
SOURCE: HOW DO I FIX A HU 850 CD PLAYER IN A VOLVO S60 2006 ERROR
You may just need to clean your device..
if that doesn't work...maybe you can ask a car radio installation company. Dealers will problem charge more.
Posted on Jan 28, 2015
khuram4narme
kays
  • 1179 Answers
SOURCE: I need a Volvo HU-850 CD HEAD UNIT
possible scrap yard
check your nearest volvo scrap yard
Posted on Nov 05, 2016
possible scrap yard
Nov 05, 2016 | Volvo Cars & Trucks
I need a HU-850 CD head unit
Fixya does not sell head units.
Nov 05, 2016 | Car Audio & Video
HU-850 radio audio goes off & on along with a constant clicking. Any recommendation's?
I've got issues with my FM reception but the CD and other components have been rock solid since 2006. Check the amplifier unit under the front passenger seat. there are several cables under there that could get damaged by the seat moving up and back with something stuck under the seat. I think there's also a preamp behind the glove box that may have some audio connections.
Jan 23, 2016 | 2007 Volvo S60 T5 Sedan
Jan 28, 2015 | Audio Players & Recorders
I need a scamatic to install a used HU 850 stereo with nav into my 2006 t5 s60
Unless you are a master automotive electrical engineer, or a volvo service tech with mainline access, this will be lots of trouble. The original head units for volvos were flashed at the dealer or factory to each individual car. Even if you got all the wires to match up between years/models, you would still need to take the finished rig to a dealer or specialist to get it "relearned". Plan on spending hundreds of dollars no matter which way you go.
Mar 31, 2014 | Volvo s80 radio hu-850. audio 2005-...
I want to purchase a pair of pioneer CDJ 850 players, however in my country the power supplied is 110 volts at 50hz. I have had problems using electronic devices that only specify 60hz. The CDJ 800's...
The 850's should work fine on 50Hz. They are spec'ed at 120/60. with your lower voltage the transformer in the power supply should NOT have a problem. There is nothing syncronized to line frequency so it should work fine.
Jun 01, 2011 | Pioneer CDJ-850 CD PLAYER
How to get cd player to work on Volvo 850 1994
do you have a cd changer or is it the cd/radio .just a thought the cd button on the radio will only work of you have a changer fitted usually in the boot
Oct 03, 2008 | 1994 Volvo 850
Aug 02, 2008 | 2005 Volvo S60
HU Shuts Down - "Protect" Blinking
if it is only doing it over 30 then you need to turn down the bass level on the deck and make up for it with the subs sounds like its putting out too much juice. also if your car has a factory amp for your door speakers ect make sure that your factory speakers are the same ohms as the cd player which is 4ohm ,most fancier car speakers are 2 ohm. if that is the case the amp on the cd player is going in to protect mode to prevent frying your factory amp if you have one. check all your wiring from the cd player to the car and make sure it is all properly hooked up and there are no crosed wires. or wire hooked up incorrectly. also make sure the amp wiring kit is big enough gauge for the amp. make sure its not the amp that runs your subs that is cutting off the HU.
Nov 21, 2006 | Kenwood KDC-X890 CD Player
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
