Question about Car Audio & Video
Enable or disable alarm. Radio code - Car Audio & Video
Posted by Amy Fryman on
2 Related Answers
Anonymous
SOURCE: Motorola E815 alarm full
At the alarm screen, highlight one of the alarms, then press the main menu button, several choices, including a delete option will be given. There is even a delete all option
Posted on Dec 18, 2007
sssi
SOURCE: how to switch auto alarm on and off
Dont know how to set the time for the alarm, but to switch it off press and hold the menu button until it asks if you want to reset the radio and then follow the instructions. It means you have to reset radio every time but at least it stops pesky alarm going off...
Posted on Jun 26, 2012
I have a Timex T311 clock radio. How do I shut off alarm and radio everyday. As I no longer need to wake in the am.
On the Timex T311, to disable the radio alarm, press the Radio Alarm button once. The Radio Alarm Indicator light should go out and the radio alarm won't sound. If you press the Radio Alarm button once more, the radio alarm will toggle to on and that indicator light will come on. Similarly, press the Buzzer Alarm button once to enable the buzzer alarm and press it again to disable the alarm.
See page 9 of the manual to see the directions to toggle these alarms on and off. The manual is available from Timex Audio on the product page: https://timexaudio.com/support/product/T311/ . The direct link to the manual is https://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf .
I hope this helps.
Nov 15, 2017 | Timex Audio Players & Recorders
Code radio lost
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Mar 19, 2013 | Car Audio & Video
How to enable alarm on sangean wr-2 clear
It's tricky but it can be done.. I should add that it'll require some patience but it'll happen. First thing is hit reset on the bottom of radio. Second thing is to interrupt the RDS (scrolling message after reset) by hitting the power button. Now long press set until it begins to flash 12:00. COUNT the flashes until the 26TH flash and hit BAND. It doesn't always work, but you'll know it does when the word alarm, an alarm clock symbol, and a speaker symbol are on the display above the time. I should also mention that it helps to switch the antenna (external & internal switch on the back) a few times (3 at least, 5 most) during both the RDS scrolling after reset AND while counting the flashes. They (Sangean) disabled the alarm, but some determined soul figured this out and it's been passed on by word of mouth through inmates. Good Luck. It's been my alarm clock on the streets here for 3 years now.
Jan 20, 2013 | Audio Players & Recorders
Can't drive due to not being able to turn off alarm, remote broken
Pull extra electric wire from the positive side of battery but
most of the time the inline fuse is viable take both cables off
put them togeatherdor15 seconds and replace buy a radio saver
and the radio shack plugs into lighter holds the radio channels you like and also radio code holds that schould disable alarm
Jan 07, 2013 | 1999 Toyota Camry
What is the pin code for this holden stereo F-TEN CDT5590. I disconnected the battery to clear airflow meter fault. Now stereo wants a code entered in to enable it.
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft radio protection.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Holden service centre andget them to enter this code for you.
Jan 22, 2012 | Car Audio & Video
I have a 1996 jetta 1.8 with a factory alarm and i put in a new radio when i put battery back on after radio was installed the alarm kept on going off and i cant disarm it with remote button or when i try...
You alarm system monitor the radio. You basically disabled the vehicle when you removed the radio. You will need the original radio with the radio code and install it back. Your driver door lock is what turns it off and what turns it on. You have a 1996 Jetta find a electrical auto repair who is willing to do this (I do this all the time) Disable the alarm first get rid of the horn there is only on on the outer drivers side the alarm horn will have to be cut. From there acces the fuse box under the driver dash find the starter relay and bypass it. There your done no alarm and you can put any radio on .
Sep 20, 2011 | 1996 Volkswagen Jetta
How do I turn off the alarm clock
Hello
The unit has 2 alarms (alarm 1 and 2). They can be used
together or independently. Alarms 1 and 2 have different
sounds so that you can differentiate them. The alarm will
sound for 1 minute unless it is disabled.
To set the alarm:
Navigate to "Set Alarm" setting mode as shown in the
Changing Settings section. The order of the settings is;
alarm 1 or 2, hour and minute.
To enable or disable the alarm:
• Press MENU until you reach alarm 1 or 2 display.
• Press [UP] or [DOWN] button to enable or disable the
alarm. "-:--" means disabled.
OK.
Sep 14, 2011 | Oregon Scientific WR108 Weather Radio
2005 tacoma with alarm
you need the radio code from the cars user manual - usually a sticky inside the CARS user manual has a list of relevant codes. RARELY is it stamped in the RADIO manual! its ******* central tonight...
Feb 21, 2010 | Audiovox Vehicle Parts & Accessories
How to switch auto alarm on and off just how to set alarm and disable and enable product is a sainsburys red dab clock radio not the one with docking station
Nov 15, 2009 | Audio Players & Recorders
Dec 17, 2007 | Motorola Mobility E815
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
