Computers & Internet Logo
Question about ViewSonic Computers & Internet
Viewsonic vx922 capacitor compaiable va1930wm montor
Posted by Charles W Jones on
Larry Ng
    Top Expert:
  • ViewSonic Master
  • 13,255 Answers
Double posted why? OP.?
NO,caps need to be new and fresh never old.
old caps are no good. for repairs.
learn that if the used old caps short
it blows up the mobo, now is more expensive top fix.
use new caps only
not once did you tell what is in your hand at all.
or photo of it
there are lots of caps inside any monitor made.
and are not all the same at all.
my guess is, ELECTROLYTIC caps. large can shaped.
with big X or K embossed on top? called explosion preventives.
like 100uf and 50v or more?
do not use , used caps of that type ever.
buy new ones
here 92,000 choices in fact
alum caps called now, (not TANT)
on the left side see all brands there, those are TOP brands
no stinking counterfeit junk here. sold.
105C best, wild example, 100uf, 100vdc. low esr, my best brand.
show me yours and I will tell you what works best.
https://www.mouser.com/c/passive-components/capacitors/aluminum-electrolytic-capacitors/aluminum-electrolytic-capacitors-radial-leaded/?capacitance=100%20uF&m=Nichicon&termination%20style=Radial&voltage%20rating%20dc=100%20VDC&instock=y
I guess this as this is 99% of most failures in the CAP world.
for sure found dead, 2008 C4 caps, china counterfeit crummy caps. C4 boom.
Posted on Mar 02, 2022
Steve Pack
  • ViewSonic Master
  • 6,359 Answers
As long as they are the same value
Posted on Apr 18, 2019
5 Related Answers
Anonymous
SOURCE: viewsonic problem
I RMA'd this probablem as well. They asked the usual questions -- try it alone, check the connections, are you using VGA or DVI... blah blah. Eventually they could give me an RMA.
They have customer support via phone on Sundays in the US, which is nice. Total time from calling to RMA was about 20 minutes.
Posted on Sep 14, 2008
Anonymous
  • 2923 Answers
SOURCE: viewsonic VA1930WM
You need to isolate the problem to see if there's a problem with the monitor or with the sound card of the computer.
To isolate this problem, please try the steps below:
1. Make sure that the monitor is properly connected to the computer.
2. Check the volume of the monitor and the volume properties of the computer.
3. Try to connect your monitor into a known working computer.
Posted on Apr 15, 2009
Anonymous
  • 239 Answers
SOURCE: i have a viewsonic va1930wm. it turns off and on.
Is ur graphic card ok?
Have ur screen tested on another PC to determine exact cause...
Posted on Feb 07, 2010
Anonymous
  • 340 Answers
SOURCE: How do I get the back off of my Viewsonic VX922
take out the 6 screws that hold the stand start from the bottom and spred the two covers apart at the split
Posted on Mar 05, 2010
Steve
  • 3290 Answers
SOURCE: I have a 19" Viewsonic VX922 that I replaced the
This is indicative of either / or CCFL back lamp or inverter.
The CCFL is a Cold Cathode Fluorescent Lamp and the inverter changes DC to AC and functions a lot like a ballast for the CCFL. You'll probably end up buying both - unless you know for sure it is the lamp or the inverter ahead of time.
Prices vary on size of lamp, etc. Most suppliers offer both the lamps and inverters and have pages to assist selecting the correct CCFL & inverter online - one such is here. There are others, too.
Please rate my reply - thanks & good luck!
Posted on Dec 28, 2010
2answers
Hi I have a viewsonic VX922 which I have replaced the caps but on ressembly I can't remember which way round the four back light small plugs go. Can you please help. Thanks Peter
If the capacitors are polarised electrolytic type then they have a + and - leads. The - lead is marked on the capacitor with a stripe and a - sign. The circuit board where the capacitors are located will be marked with a - sign, make sure the capacitors are located correctly acording to the markings.
You need to put the capacitors with the correct values (capacitor) in the correct place on the circuit board.
If the capacitors are non polarised type the it does not matter which way they are inserted on the circuit board, but they have to be the correct value (capacitor).
2helpful
I have a Viewsonic VX922 My led power goes on and off and the screen flickers then finally screen is black.
Defective power board can cause of on and off the led power, the boated electrolytic capacitor of secondary power supply and inverter area, shorted semiconductor of inverter area. The electronics repairman can fix this.
Having trouble powering up my Viewsonic VX922. See the analog data, but have to power down for 20 sec (several times) to get the digital data on the screen
bob_loopeker, If you know that your pc is ok with different monitor then you will need to inspect the power supply board inside your VX922. All you need in the way of info is here on fixya!! All you need to do is read and make decision on what to do. Spend some time reading in my fixya profile or do "ctrl" key and click on "vx922 19" monitor" that is highlighted in light blue text above. May need new capacitors installed on unit's "switch-mode-power-supply" printed circuit board. hopre this helps. 12fixlouie
13helpful
2answers
Green light flashing on and off and computer screen will turn on when feels like it
The flashing green power button is a well known electronic problem with this (and other) Viewsonic LCD monitors. There is YouTube video (do a search) showing how to disassemble the VX924 (very similar to the VX922) and find out whether the problem is related to blown capacitors. When I took my VX922 apart I discovered 6 bad capacitors out of a total of 7 on the power supply circuit board.
Need a power supply for View Sonic VX922. Where
Here is a link for your View Sonic power supply:
http://www.shopzilla.com/laptop-power-adapters/viewsonic-power-supply/9177/products
It should have a replacement for you.
My viewsonic monitor is havind problem like constract& brightness is adjusting automatically what to do?
go to toms harwaere.com for viewsonic vx922 problems. Solutions for green power light blinking are there. Solutions say to replace the capacitors
My monitor is getting off
I have a similar issue. A search at Tomshardware web site suggests that faulty capacitors are the issue and that this is a widespread problem certainly with the VX922. Several guys on the Tomshardware post claimed that replacing the capacitors solved the problem (their units were out of warranty anyway).
Viewsonic VA1930WM
2helpful
The blinking green light on VX922
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact Viewsonic to find out a Viewsonic service point.
See:ViewSonic - Support & Service
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Top ViewSonic Computers & Internet Experts
Steve Nordquist
Steve Nordquist
Steve
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
