Question about Frigidaire Ovens
What built in oven replaces a Frigidaire Model FEB24S2ASB
My oven burnt up and I need to replace it. Do you have a current oven that will fit the cut out of the that model
Posted by Ray Pellegrino on
gbaughma
  • 5 Answers
I know this isn't directly answering your question, however, what "burned up" about it?
You can get just about every part that fits that oven from Sears PartsDirect. Control boards, bake elements, convection fans, switches, replacement glass... just about everything.
Unless the oven literally burned through the side/top walls, you're most likely going to save money by fixing whatever's wrong with it.
Even the clock/timer control board is only $164 for the OEM part.
Posted on Apr 18, 2019
5 Related Answers
Powerman
Charlie Popeck
  • 68 Answers
SOURCE: Double 27" oven Model No.911.48489 show F9,later beeping
The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
Posted on Oct 02, 2007
Anonymous
  • 45 Answers
SOURCE: Need heating element for old Hotpoint built-in oven
Midwest Appliance Parts
2601 West Diversey
Chicago, IL 60647
1-800-621-1932
- Toll Free
1-773-278-1300
- Local
Supply a wide range of hotpoint oven heating elements
Posted on Apr 11, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: oven will not light. it is a frigidaire model #
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Posted on Dec 17, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: how do I remove the oven door of Frigidaire Model
Hi.
You have to open the door all the way through.
Then remove the two locks from the hinges.Pull the tabs out, help yourself with a screwdriver.
Grab the door firmly on both sides, pull up the top of the door and slide it out.
Here all diagrams and parts for your appliance.
Regards.
Posted on Mar 04, 2010
Anonymous
  • 269 Answers
SOURCE: can i purchase a replacement seal for around the
That seal you should be able to order from any appliance spares supplier the Zannussi part number is. 3577252020. cost in euros. € 10.20 + vat.If it is the one I think it is then it is not easy to fit.The screws around the whole front panel have to be slackened off and the front prised forward dont take off fully pull old one off the new one has to be pushed in behind lip then fix all screws.may be easier with door off.
Hope I helped.
Posted on May 07, 2010
Testimonial: "Many thanks for your advice regarding the replacement door seal on my Zanussi oven. It does sound a little complicated to do the replacement, it may proove better to ask if the seal can be fitted by an expert repair man / woman, rather than me/ husband. I shall ask my local appliance shop for a cost price. I thought it may have been a quick D.I.Y. job thaks very much for your assistance "
My broiler element has burnt out and i need a replacement its a GE built-in oven model number JKP15
See this link, then click on the exact model number for your appliance. Navigate to the section of the oven containing the part you require:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JKP15
Apr 02, 2011 | GE JKP15 Electric Single Oven
Installing part 903091-9051 in a wall oven Frigidare FEB24S2ASB
YES ITS NOT SO BAD. I RECOMEND TAKING ONE WIRE OFF THE OLD AND PLUGGING ON THE NEW ONE AT A TIME SO YOU DONT MISSWIRE.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 07, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Power surge fried Frigidare FEB24S2ASB
The electronic oven control has gone bad. The repair is a lot less expensive than the replacement of the whole stove. Part number is 903091-9051 at about 165.00 retail. You can fix rather than replace whole stove. Hope this helps.
Mar 04, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
My Frigidiare oven FEB24S2ASB won't turn broil on...either the button on the console is out or the element is out...don't know how to determine it.
The heating element must be checked for continuity, using a multimeter set on impedance (ohms) reading at the two element contacts.
In a similar way you check that the wiring are ok.
To test the board you start with an eye observation to find out if thee are burnt spots or components that had blown, if you do not find anything , you need again a multimeter to test the board.
You find schematics and parts by entering model number here.
Jan 05, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
Getting a manual for a range
Frigidaire Electrolux oven I phoned a 1-800 number at Frigidaire. They told me they had to search microfiche to find out about that particular model. They found the manual on microfiche but then gave me another 1-800 number to see if I could get a hard copy or a pdf. But I thought if I get a manual for a normal Frigidaire oven that is current, there can't be too many differences. I just wanted to understand the priciple and application of convection ovens and how to work the electronic keyboard. A couple of burnt turkeys later, I will get the idea. Thanks for your enquiry. ZOE!
Jun 13, 2008 | Ovens
Ovens Logo
134 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
