Question about Laser Office Equipment & Supplies
Scanner error 6 in laser jet 3052 - Laser Office Equipment & Supplies
Posted by Mukesh on
Ubaid abid
    Sergeant:
  • 164 Answers
"Error 6" indicates a common problem with LaserJet, a brand of dry electrophotographic laser printers from computer technology company Hewlett-Packard. One of such machines is the HP LaserJet 3390, an all-in-one printer that can print, copy, scan and fax documents.
Posted on Apr 20, 2019
5 Related Answers
Anonymous
  • 75 Answers
SOURCE: HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Posted on Nov 04, 2009
Anonymous
SOURCE: scanner error 6
my hp 3052 suddenly stops, and there is a display "scanner error 6,turn off then on" Of course i did turn off and on several times but it keeps on coming back.
Posted on Feb 06, 2010
Anonymous
  • 160 Answers
SOURCE: laser jet 3055 scanner error 6
Generally, Error 6 is a failure of one of the PCA boards and the unit requires service.
Posted on Apr 20, 2010
Dimitar Todorov
  • 241 Answers
SOURCE: HP Laser Jet 3600 it has a 51.23 error I
Try replacing interconnecting cables - flat ones
Posted on Jun 14, 2010
Testimonial: "It was the cable under the pick up assembly"
Al Toledo
  • 223 Answers
SOURCE: HP Laser Jet 3055 is
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
NVRAM INIT
1. Turn off the all-in-one
2. Press and hold down the * and enter buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. Allow the all-in-one to return to Ready before using it. storage init. appears, and then release the buttons.
if this does not work contact hp 1800-334-5144.
Al
[email protected]
Posted on Jul 15, 2010
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
Scaner error 52 in my laser jet printer printer model :-hp laser jet 3052 all in one printer
52 Scanner Error
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the FFC connection between the formatter and the scanner.
NOTE Do not bend or fold the FFCs during the removal or reinstallation process.
4. Try connecting the product to a different power source or surge protector.
5. Turn on the power and wait for the all-in one to initialize.
6. If the error persists, replace the laser scanner assembly.
Jul 12, 2011 | HP LaserJet 3052 All-In-One Printer
Long time scanner warming up display & then scanner error
open the scanner unit clean all the glasses and mirrors with lint free cloth, that they are dust free and get shinning. the problem is solved.
Aug 31, 2010 | LaserJet 3052 All-In-One Printer
My hp laser jet 3052 cannot scan documents in pdf.It is only giving options to save either in jpeg, tif, bmg format. There is no pdf format.
You may need to purchase a scanner to get a PDF like Acrobat Reader. But if you managed to save to PDF before, try to reinstall the software and add software and choose OCR. Most of the HP PDF capablility is together with its OCR software.
Aug 22, 2010 | LaserJet 3052 All-In-One Printer
Laser jet 3055 scanner error 6
Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
The HP Laser Jet Scanner 3052 cannot connect to my PC?
check whether you have installed the appropriate drivers for your scanner. If you didn't installed it then download the correct driver and install it.
Jul 15, 2009 | Computers & Internet
Scanner error 6
Apr 27, 2008 | Office Equipment & Supplies
HP Laserjet 3052
i am getting scanner error 5 in my hp laserjet 3052, pls giv me the solution for the same
Jan 29, 2008 | HP LaserJet 3052 All-In-One Printer
Top Laser Office Equipment & Supplies Experts
efs_perpends
efs_perpends
ADMIN Canada
ADMIN Canada
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
