Question about Sharp Audio Players & Recorders
I have a sharp spc374t and would like to know how to set from military time to regular. thank-you
Posted by philip budry on
5 Related Answers
Anonymous
SOURCE: Getting the clock off military time
With the sytem off, hold down the Alarm Setup button and the On/Off button to switch between 12 hour (AM/PM) and 24 hour (Military) time. If you need the manual go to
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/music_system.jsp
Posted on Dec 06, 2007
Anonymous
SOURCE: Bose Clock
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold
down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military
(24 hour) time formats.
Posted on Mar 03, 2008
jackmc
SOURCE: Military time
I have the same problem. The clock changed to military time after we experienced a power failure. I have tried to correct it by holding down the "Alarm Set" button and hitting the "On/Off" button at the same time. It works while the buttons are pressed but immediately reverts to milirtary time. Any other suggestions?
Posted on Jun 15, 2008
Ekse
  • 13435 Answers
SOURCE: How to set the time on Athletic Works watch
Press and hold the lap/reset button for at least 5 full seconds. You should see the word "SET" appear in the dispaly. Push the Mode button to change from alarm to date to month, time, etc.. Use the start/stop button to change the numbers.
Posted on Jul 13, 2009
Anonymous
  • 35 Answers
SOURCE: have ds time from military to regular
you have to go to the main screen then at the bottom of the screen there will be a small DS click that and you will hit the menu
Posted on Aug 09, 2009
To be able to change to analog time from military time
Go to your events/calendar. Click the little settings symbol there. Then uncheck 24-hour time and save. How do I change my clock settings from military time to regular time.
just found this on the internet dont no if this will help you out if not let me no.
Why does time keep switching to military?
you have it set on 24 hour time instead of 12 hour time
it will change over at midnight to military time as that is when the 24 hour period ( military time ) starts
1helpful
Rca led tv shows military time is there a way to change it to regular time?
Having the same damn problem it's not in the settings menu or I would have changed it would need to know how to change this to regular time it's very annoying
1helpful
My timex indiglo Ironman triathlon watchhas twelve hours of military time and then twelve hours of regullar time. HOW CAN I GET RID OF THE MILITARY TIME AND GET ALL TWENTY FOUR HOURS OF REGULAR TIME???...
Actually all the hours are military time. They are the same for the first twelve hours of the day. If you go through the setting procedure it will ask you if you want "12" or "24" hour time. Select 12. "24" is military
This is controlled by hardwired switch (12/24) OR digitally during menu setup sequence.
13helpful
3answers
Bose Clock
6helpful
2answers
Setting time & alarm on Sharp Chronograph wristwatch.
Instructions for Sharp Alarm Chrono (Digital)
Push "Mode" button until the mode is shown that you want to reset, do this even if the mode you want to reset is all ready showing.
Push "Reset", continue pushes until the desired Parameter (Minute, Hour, or Second) is flashing.
Use "Start" button to advance the digits to the desired setting.
Push "Mode" Button to finish.
Jan 12, 2008 • Watches
30helpful
2answers
Top Sharp Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
