Question about Video Game Consoles & Games
I have a Taylor C713 and it beeps when on standby mode. Why ?
Posted by Nadine Hechema on
1 Related Answer
qasolution
jeff bennett
  • 107 Answers
SOURCE: beater overload
if your mix level is low ice cream will freeze in cylinder which in turn will over amp the beater and cause it to trip. Check mix pump and make sure all orings are good.If mix isnt leaking out make sure it is pumping in.
Posted on Apr 19, 2012
WHAT IT MEANS R-HPR THERMAL FAIL FOR TAYLOR ICE CREAM MACHINE MODEL C713
That code means the right side hopper thermistor probe has failed. That is the sensor that reads the temperature of product in the mix hopper.
This is the part you need:
http://www.softserveparts.com/i-26471492-thermistor-probe-c712-c713-barrel-stanbye-probe.html
If you order it from us, I would be happy to put a technician on the phone to help you install it yourself.
Aug 01, 2017 | Taylor Ice Cream Makers
Why would a Taylor C713 be making darker and icier soft serve than normal?
I generally see this happen when the air to mix ratio is off. This generally happens overnight when the machine is in standby someone forgets to flip the feed tubes so that no more product is drawn into the freezing cylinder.
Your viscosity could also be set too low.
Jul 29, 2017 | Taylor Ice Cream Makers
Taylor ice cream machine model C713-33 no yogurt comes out when the draw handle it pressed. It seems to be flowing backwards. The agitators are turning in the same direction as the working machines
IF your Taylor C713 is pushing the mix back up through the feed tube, the rotation is reversed. That would only happen on a 3 phase machine like yours.
If you've recently unplugged the machine to move it or something, you probably switched the plugs. Try switching them back.
If you need to reverse the rotation:
1. Unplug the machine.
2. Flip the black and white wires on the plug end.
3. Reassemble the plug and plug in the machine. Make sure everything is tight.
Soft Serve Parts C713
Jun 10, 2017 | Taylor Ice Cream Makers
I just replaced the two beater drive motors on my Taylor c713 ice Cream machine now when I power up communication failure comes up
Every time I have seen that, it is just the USB cable on the mother board in the back of the machine.
1. Shut off and disconnect the machine from power
2. Remove the rear panel
3. Remove the electrical panel cover
4. Find the USB cable on the bottom of the board all the way to your right.
Mar 26, 2017 | Taylor Ice Cream Makers
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
My Taylor c713 is on "R Beater Overload", I came into the shop to find it had done this over night.. I emptied the ice cream out of the machine and cleaned it, upon pushing the reset button and trying to...
That is most likely the stand by probe. The standby thermistor probe measures the temperature of product, in this case in the freezing cylinder, while the machine is in standby. Usually when the thermistor fails, you come in in the morning to find that the product is liquid and the reset has been tripped. The motor should be nowhere near the overload setting in standby as the product should be liquid. Thermistor probe C712 C713 Barrel Stanbye Probe
Oct 12, 2013 | Taylor 632-33 Ice Cream Maker
Barrel Therm Bad, keeps beeping on right side
Pretty much what it sounds like, the thermometer in the freezing chamber (barrel) died, and you can't operate until it is replaced. Drain all yogurt and clean and unplug. You need to call a technician out; call 800.255.0626 to find out your local service center.
Sep 15, 2012 | Taylor Crown C713-27 Soft Serve Ice Cream...
Video Game Consoles & Games Logo
96 people viewed this question
Top Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Tom Chichester
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
