Question about Proscan Televison & Video
I bought a proscan tv model# PLCD5092A-B but I try to set up the channels, a blue ray or anything I hook up it says no signal
Posted by Juan J. Hernandez on
5 Related Answers
paul proctor
  • 4102 Answers
SOURCE: Hooking up XBOX 360
Hi have you tried going into the menu option using the telly controll and switching the hd mode on this should then allow you to use the xbox through hdmi cable
Posted on Feb 29, 2008
Michael Borelli
  • 979 Answers
SOURCE: no channels
Are you using a set-top converter box?
Posted on Jul 01, 2008
Michael Borelli
  • 979 Answers
SOURCE: no channels on the list
Be sure that you are on the "Tuner" input, and that if you are using a converter box, that you have the set tuned to the single channel that the box puts out. (In the US, that's either 3 or 4.)...accordianman
Anonymous
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Posted on Aug 12, 2009
Anonymous
  • 336 Answers
SOURCE: I just bought a Blue Ray player but my surround
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Posted on Nov 21, 2009
EEPROM for proscan main bd c12090002 mod plcd5092 a- b
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
How do i get warenty work done on my 50" proscan tv. i bought it at K mart. Do i take it there ?
suggest phoning kmart store and asking them where the nearest warranty repairer would be for the tv.
I want to watch netflix on my proscan tv, but I've put the tv on every channel and netflix doesn't pop up
it could be that your scrolling the channels and ports for your dish network menu and not your tv menu if your using a remote try changing the setting via the tv itself, also try disconnecting the dish network supply then try try using the net gear stuff, personally I would say get the new x-box one system because it has blue-ray capabilities, stream music and videos, movies, it has Netflix and hulu and all that stuff that your computer and phones can do now including video chat, voice recognition, hands free movements recognition and yeah it just does everything... hope this helps
How to unlcock proscan tv model # plcd5092a
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
1helpful
Hi- I bought a used 37LC model (less than 1 yr old) without a manual. I cannot get any over the air local stations to come up under the TV mode. Does this model have a normal tuner ? The display shows...
if the display says cable, it won't get over the air signal. switch the source to antenna, hook up an antenna and go through auto program sequence.
2answers
Sony RDR-VX535 I tried hooking it up to just a TV, no cable box or anything else. I put the 3-pin cable from the Sony's Output to my TV input (only has yellow and white on TV, no red). However, when I...
Red is Audio Right
White is Audio Left
Yellow is Video
You don't say what TV you have so it's impossible for me to guess what the connection it is that you are using. You will not see a signal on any of the channels you will need to select AV or Mode or Input or something similar on the TV
Televison & Video Logo
Top Proscan Televison & Video Experts
Ekse
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
