Question about Watches
Why will my new watch lc9043 not run? - Watches
Posted by RICHARD L GARLITZ on
New Armani exchange watch. Set time and date. It doesnt seem to be running. Is there a secret?
The secret is a new battery. People are always shocked when they get a brand new watch and it isn't running. How do you know how long it was sitting on the shelf of the factory or the retailer? A battery is usually good for 1-3 years... May have just expired.
Dec 25, 2013 | Giorgio Armani Watches
Brand new Hamilton automatic watch, but we can't get it started running.
If this is a self winding watch then you will have to rotate the pendulum inside it about 200 times before it will start. The directions should show you the proper way to rotate the watch to move the internal mechanism.
Dec 25, 2012 | Watches
My watch wont run
sometimes when u buy a new watch they have it turned on for display try getting a new battery.
Jul 26, 2012 | Invicta Diver Watches
Elini New Yorker stopped running. could it need a battery? Where can I take it?
Yes, normally if a watch stopped running it needs a new battery. Well, you can bring it to the nearest watch shop in your area.
Sep 17, 2011 | Elini New Yorker Grand Chronograph Red...
Brand new watch does not run
the problem is the battery of the watch. it has to be replaced by new one, it is new but it probably sat for a long time in selling shelves that when the time you purchased it, it is out of battery charged. you can bring it to the watch retailer store from where you bought it and you can ask for the warranty of your watch. i hope i had been helped you.
Aug 01, 2011 | Nixon Time Teller P A119211 Watch for Men
MY Omega Speedmaster watch runs fast. How do I
Hi dgcgo. My advice, unless you're a watchmaker, is to take it to an authorised dealer or trusted watch repair shop, and get it done properly. The speed on automatic watches is adjusted by means of a tiny regulator, but the adjustments are minute and the watch is then usually bench-tested to make sure it is running ok. It's an expensive watch, so worth the effort, although if it's new, you can probably get it done under guarantee. Cheers; Eagle58
Jul 04, 2009 | Watches
Tropby radio controlled watch, runs slow, even with new battery
Your watch is need to clean an replaced the old oil in gear shafting that is the common problem of a watch when the old oil is sticky already thats makes the gear moves slowly and your watch is always late . If ever your watch was already clean and replaced new oil and still working slowly then the problem is in the circuit board is near to run out its needs to replaced whole circuit board so its better again. I know this because im a technician in Rolex service center before. Feel free to ask whatever the result.
Hope it may help you;
Regards;
VOTIT
Jan 30, 2009 | Bulova Watch
Backwards watch?
if you just got the watch then I would take it back. Other wise you are going to have to send it in. None of the casio watches should run backwards. Call repairs and tell them what's going on. 800-706-2534 and then option 2.
Jul 31, 2007 | Casio G-Shock G701D-2AV Wrist Watch
Watches Logo
109 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
