Question about OKI Office Equipment & Supplies
I also did full default reset from admin webpage and from maintenace lcd menu. I also disconnected printer from power AC for 1 hour. Any other ideas ?
Sometimes if there was a paper jam and someone removed it without getting all of the paper, then there could be a small piece of paper still in the way of the sensor. If you have any compressed air it might help to blow it out of the sensor area. I have had issues with that in the past as well, so I opened up the area it said it was jammed - gave it a good going over with the can of compresses air, and it seemed to clear out the jam.
Posted on Apr 18, 2019
Testimonial: "No it is not a paper jam problem. It looks like microcontroller problem. I did sensor check under service menu. CVO UP_LU_FU shows 1.L 2.* 3.H 4.* where H is close. 1 is Cover-open switch and 3 is rear cover. So system is reading from sensor 3, but is not reading state of sensor 1. As i sad i checked Cover-open switch and it is working, i also shorted pins(pins related to cover-open switch) on mainboard and this won't work too. So in conclusion there is some bug in firmware or some part on mainboard is out of order. Any ideas ?"
SOURCE: Panel Lights stay on at power on
the problem is the fuser is shot, they are still available and you might think about replacing the fed and sep tires at the same time.
Posted on Feb 18, 2008
SOURCE: mfc-7220 Back Cover Open
This one made me crazy, but I finally figured it out. Turn the machine around so that you are facing the back. Open the back cover. Pull down the second smaller roller cover inside the machine. If you look closely at the second smaller cover, on the right hand side (closer the the inside of the machine), is a very thin round piece of plastic that is only half the length of the smaller cover. There are 2 thin plastic tabs attached to either end of this round piece of plastic. Gently shift this over so that the 2 plastic tabs can now go into the space provided for them. I had to move mine over only 1/4 inch.
Posted on Nov 13, 2008
SOURCE: Error: "Back cover is open. Close back cover."
We had this problem. It turned out there was actually a piece of paper stuck in the printer! It wasn't so easy to see it from the rear.
We removed the paper from the front by taking out the ink cartridge first. Turned the printer back on and everything was fine.
Posted on Apr 06, 2009
SOURCE: Brother DCP 7020 error 'back cover open close
Posted on Mar 11, 2010
SOURCE: I cannot get the BACK COVER OPEN message to GO
There is a little cover there that has a sensor flag on it. It is most likely in a jammed position. If you are able to carefully take the cover out, you can bend it slightly, readjust the sensor flag, and reinstall it.
Thanks
Posted on Mar 12, 2010
Jun 03, 2015 | OKI Office Equipment & Supplies
Aug 30, 2014 | OKI B4600 Laser Printer
Jul 16, 2014 | Oki Electric Industry B431d Printer
Dec 27, 2013 | Sharp Refrigerators
Nov 09, 2011 | HP Office Equipment & Supplies
Jun 18, 2010 | OKI C3400n Laser Printer
Feb 11, 2010 | OKI OL 400e Led Printer
Feb 08, 2010 | Lexmark C510 Laser Printer
Dec 21, 2009 | OKI B4350 Laser Printer
Nov 23, 2009 | OKI C3400n Laser Printer
71 people viewed this question
