Question about Rowenta Irons
My Rowenta DM 273 just stopped working. Plugged it in & no heat, lights, nothing. Any ideas where I should start looking?
Posted by Hank on
Steve Pack
  • 4,331 Answers
There is no repair parts so replace it
Posted on Apr 17, 2019
3 Related Answers
Anonymous
  • 50 Answers
SOURCE: rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Posted on Mar 14, 2009
Anonymous
SOURCE: Rowenta DM 273 Iron
It is a Torx tamper proof screw-call 925-827-1011 and order a "Rowenta tool" $10.00 plus shipping this place allso sells Rowenta parts
Posted on Jul 06, 2009
caroldon
  • 17130 Answers
SOURCE: Rowenta DM-880 steam button sticks. Spray button
It is possible that there is dirt that has accumulated into the stem of the steam button and is sticking the button. It is better to remove the lid and make a good cleaning to free the movement. use good spray of jet air, use WD40 to remove dirt and free
This will work for sure.
Posted on Aug 21, 2010
Iron heating sporadically and sensor lights working sporadically
It looks like the cord has a loose connection and will need to be replace.
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta DM-880 steam button sticks. Spray button works fine. Any ideas? Thanks.
Aug 21, 2010 | Rowenta Professional DE880 Iron
Rowenta precision iron DM 561 will not heat up
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
Turns on, flashes yellow but never heats up
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jan 12, 2009 | Rowenta Effective DX1900 Iron with Auto...
My rowenta effective will not heat up.
Dec 15, 2008 | Rowenta DG5030 Iron
The light is on...but no heat at all?
Aug 10, 2008 | Rowenta Powerglide DE011 Iron with Auto...
Rowenta DM 273 Iron
Jun 13, 2008 | Rowenta Professional DX8800 Iron
Brand new rowenta professional won't heat
The mostly problem in that case is the internal terminal from cord to iron is loose ,open it and fix the the terminal cord to iron,or go to the nearest shop to repair that.
Thanks & good day,
Edgz
Feb 12, 2008 | Rowenta DZ1700 Iron
Irons Logo
176 people viewed this question
Top Rowenta Irons Experts
Colin Stickland
Colin Stickland
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
