Question about Saws
What's correct wiring diagra2 for B&D circular saw#7391 type 4???
Posted by Billy Hess on
5 Related Answers
Anonymous
  • 2712 Answers
SOURCE: circular saw Types
There are for types of circular saws available. 1. Worm Drive - The motor is in line with the blade, delivering enough torque to carve up wet lumber or saw through concrete, which makes a worm drive ideal for framing or major renovation jobs. With the handle farther back, a user can better resist kickback and steer the 16-pound saw through long rips. 2. Sidewinder - The motor sits alongside the blade, making for a lighter (11 pounds or less) saw, which is more maneuverable over a long day than a worm drive. 3. Small Sidewinder - Weight, balance, and handle size are all key features to consider when choosing a saw that fits you. For a slight-bodied person, a small model may be more appropriate than a full-size sidewinder. 4. Cordless - Battery-driven models have increased in size as their power packs have gained voltage, making them convenient tools out in the field or when the electricity's not on. However, cordless models still have limited run times and generate less torque than corded saws. 5. Trim Saw - For finish work or paneling, this is your best choice. blades range from 3½ to 412 inches.
Posted on Aug 27, 2008
Anonymous
  • 11 Answers
SOURCE: My 7 1/4 in Craftsman circular saw stops running.
Is there anything jammed between the blade and the body/guard of the saw?
Posted on Jun 26, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: How much/what type of oil goes in my old wormdrive saw?
their owners manual doesn't give an exact quantity however they say to unplug the tool first then remove the fill plug and the lower plug and the oil should run out past the first thread. they recommend using their oil 80111 8 oz. tube however any good worm drive lubricant will work, Don't use anything like gear lube because the worm drive lube has an additive for anto foaming. Let me know if you need more assistance
Posted on Jan 24, 2010
Anonymous
SOURCE: looking for user manual Rockwell Model 215
hey there i just bought a used 215 7-
1/4" saw it came w/ a manuel
maybe i could copy it for u and send it to you [email protected]
Posted on Jul 26, 2010
Anonymous
  • 178 Answers
SOURCE: I have an old Rockwell 368 circular saw 81/4".
Well, here is the link for the breakdown of your peticular saw
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=368&selectedType=11998
As far as the manual, the closest you will get without finding one at a garage sale is the 368-1 Type 1. When Porter-Cable absorbed Rockwell's tool line, they kept this saw and threw a -1 on the end. Some parts are different, but the operation is the same, thus, the manual should provide any information you may need, but I'm sure that you would just like to have it, and probably don't need it. Here is the link for that. Just click on the Instruction PDF Icon.
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=368-1&selectedType=13481#
I hope this helps.
Posted on Nov 29, 2010
I have a Milwaukee circular saw, 6365, and am replacing the switch. Need a wiring diagram!
Scott,
What is the serial number on your saw? I need that to make sure I get the correct info for you.
May 30, 2015 | Milwaukee Tool Saws
My circular saw is not working now. Help me what to do.
broken contact powercable , switch but measure to carbonbrushes to each other with signal measure multimeter , the autostop in the carbonbrush can be activated. or 1 of the 4 wires on the electricfield is broken
Apr 13, 2015 | Sears Craftsman 7-1/4 in. Circular Saw...
Check brushes...
Dewalt Craftsman 2 Pack Carbon Brush Holder for Saws 147097 09 2pk
or sometimes the switch fails...
Craftsman 7621301 Circular Saw Switch
if you luck out, it may just be a broken wire, right at the switch, or right where it enters the saw? Pulling the, or directly on the cord vs. just the plug puts a lot of strain on the wires.
But if it is one of the parts above, very easy repair.
Apr 13, 2015 | Craftsman 7 1/4" 12 Amp Skill Saw
Need parts for Black and Decker circular saw model 7390
Go to
http://www.ereplacementparts.com/black-and-decker-7390-type-circular-saw-parts-c-4167_4252_12157.html
Jan 24, 2013 | BLACK and DECKER POWER TOOLS Black And...
I bent the depth of cut scale on a Craftsman 7-1/4 in. Circular Saw. How to true it so I can again set correct depths?
With the saw unplugged, lay it upside down on a bench or table. Put a small scrap of 2x4 against the blade and adjust until the depth of the blade matches the thickness of the 2x4. Lock it in place, Then bend or adjust the depth scale so that it reads 1-1/2 inches. Good luck.
Dec 10, 2012 | Sears Craftsman 7-1/4 in. Circular Saw...
I need a switch for my black & decker 7 1/4 worm drive saw model 7395 type 1
That tool was discontinued in 1980 and parts are obsolete. You may be able to use a Skil 77 worm drive switch as many of the circular saw switches were configured the same. The switches are usually marked with a 1 and 2 on the back so make sure the wires are put on correctly as some will have the 1 on one side (top and bottom terminals) while others are on the top or bottom (next to each other).
Aug 05, 2012 | Black & Decker 7 - 1/4" Heavy Duty...
Change power cord in saw
The correct way is to split the handle and change the power cable at the connectors as per the original. One wire - the live - may connect straight to the switch while the neutral will connect to a blue or black wire leading further into the machine. Make sure that the machine is unplugged before attempting any repairs and make sure that the earth wire - if it has one - is firmly grounded on the machine frame. If possible, use lugs which correspond to the original ones on the cable ends, it is a much neater and safer connection than just twisted wires.
Avoid joining power cables, but if you must, make sure that the joints are staggered and soldered, individually insulated and then covered again as a unit. Heat Shrink sleeving is the correct method to insulate power tool cables.
Feb 24, 2011 | Makita 7 1/4" Circular Saw 5007NB
Dewalt power saw wiring diagram for trigger switch dw-708 type 4 wire colors to swith positions.
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
Apr 12, 2009 | Dewalt Saws
Saws Logo
160 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
