Question about Konica Minolta bizhub Office Equipment & Supplies
I have a Bizhub 4752 it is making a grinding sound when I print from the computer but when I do a straight copy it does make that sound. Please assist
Posted by Gisele Lovence on
Ubaid abid
    Sergeant:
  • 164 Answers
If u installed ADF on Ur machine then check the ADF feeders if not .. then check scanner Assembly
Posted on Apr 20, 2019
5 Related Answers
Anonymous
SOURCE: Makes grinding sounds & usually prints blank
Changing the toer cartridge completely fixed the problem. I returned the defective genunie Bher toner. thak you!
Posted on Aug 14, 2007
Eric Engel
  • 122 Answers
SOURCE: Symptom: Grinding sound.
This could be either your drum cartridge or your fuser unit.
Take your toner cartridge out and look right up front where the drum cartridge empties 'waste toner' back into the toner cartridge.  There's a little flap there that slides back and forth on the very end.  Slide it back and see if toner is packed in there solid.  If so, vacuum it out.  Then you'll have to replace that drum.  Sometimes you can salvage them by cleaning out all the waste toner, but usually the gear in back has already stripped and it's no use.
If everything looks fine with the cartridges, it's probably the fuser.  You can buy a new one here:
http://www.acrat.com/xeroxfuser.htm
The fuser is that part of the machine that gets real hot.  If you open the right side door, it'll be right close to the top.  There are usually 4 screws holding it in place.  If you take those screws out, you should be able to hold it away from the machine while it's running (you'll have to cheat the door).  If the grinding stops as soon as you pull the fuser away, that's probably your problem.
Let me know if any of this sounds too technical.  eric AT essonline.us
Posted on Oct 31, 2007
jmassengill
Johnny Massengill
  • 345 Answers
SOURCE: Bizhub C350 - Print spooler not running after power outage
I would print out a copy of the network configuation of that printer and ensure it has the proper network settings (I.E. IP address, Subnet mask and Default Gateway. I just worked on a printer that I accidently pull the plug on and it lost it's network settings and wouldn't print until I changed them back to the correct settings.
Good luck
Posted on Nov 11, 2008
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: Hi I own a Konica Minolta Bizhub 600 whenever I
Look to see if the paper trays are set to the correct paper size. Also, look to see if the zoom is set to auto or at a 100%
Posted on Sep 18, 2009
Testimonial: "Thx! Unfortunately all those characters have already been checked, it seemes to be another kind of problem, any other thoughts?"
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: Malfunction(Code 3451) of Bizhub C252
This is a fuser heat error. The fuser unit is located in the area where the paper exits the machine. It heats up and "fuses" the toner onto the paper. The error code means that it did not heat up properly. This means you will most likely need a service person to come out and diagnose the problem.
You can try to reset the error but I doubt it will help.
Turn off the MAIN power switch (not the one on the control panel)
Now hold down the utility key while turning on the main switch and continue holding the utility key for at least 10 seconds. You should see a screen come up with nothing but "trouble reset"
Touch trouble reset and you should see a small "ok" come on. Then turn off then on the main switch again.
Good Luck and Thank You for using Fixya.
Posted on Apr 01, 2010
Printing copies crooked
prints ok from a different tray????????????????????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 14, 2014 | Konica Minolta Bizhub C224 Color Copier /...
No print on copy in bizhub konica 280c copier
replace the yellow image unit
Dec 17, 2013 | Konica Minolta bizhub C250 All-In-One...
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
I need instructions on how to de-scale.
The Owner' s Instructions for your CC80 can be found here:
http://dl.owneriq.net/3/334f817e-6ca6-4752-a5bf-540d618a7178.pdf
You may want to print a copy and save; DeLonghi sells copies for $4.99.
Refer to pages 8 and 9 for cleaning and descaling instructions.
Jan 30, 2011 | DeLonghi CC 80 Coffee Maker
Hi my copy is bizhub 350 and have a problem in printing. when i send a file to print in the copy screen only for a one secound apear a job list and this job automaticly deleting. please help me
this will happen if account track or authentication is enabled on the machine to enter a password for the driver go to the driver properties and click on printing preferences then the user authentication/account track button and you can enter your password there it would be the same password that you enter to make a copy
Oct 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C 250 stops printing! Hepl please!
Sounds like the controller has crashed.
If you have a Fiery, reboot it and see what happens.
If that does not help you better call a Technician as it may need to be reloaded.
Sep 08, 2008 | Konica Minolta bizhub C250 All-In-One...
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printing Problem
sounds like the fuser is offsetting, i.e old image is sticking to it and being offset onto the next page going through it. I'd look at replacing the fuser first.,
Oct 10, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
37 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
