Question about Hardware & Accessories
MODEL RECTIFIER CORP .TECH 2 DUAL POWER 2800 what is the wattage of this power pack
Posted by Ralph Isaacs on
Vernon Taylor
  • 6,991 Answers
Google search revealed the following - "The 2800 is rated at 10.6 VDC, 8.5 VA which translates to 1.25 amps",
which is rather confusing as VA for practical purposes is the wattage (of the output) and 10.6 volts at 1.25 amps is wattage of 13.25 while the quoted VA of 8.5 suggests a current of only about 0.8 amps is available which I think is somewhat unrealistic. This is presumably for each output...
Posted on Apr 17, 2019
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I switched the Pc on after connecting all cables, the monitor didn't come on thats when i found that the power pack must have died as icould smell a bit of burning. the motherboard light is on ( green )...
most power supply units will fit you can get a larger wattage output eg: heavy duty if you have added any more devices to your computer more RAM,a larger hard drive,more cd/dvd drives these added will put a greater need for wattage output on the PSU
you should check all the electrical connections before you make a decision and make sure they are the same as as the ones that you will need to run your computer also
check the measurements inside the frame to make absolutely sure it will fit
you can get lots of PSU
Feb 24, 2011 | Alienware PC Systems Alienware True 480...
My malibu landscape 300w transformer does not want to come on
Check that power pack is getting electricity.
Power pack should make a small humming sound when on.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional voltage can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Nov 22, 2010 | Intermatic Malibu 300W Power Pack...
My lawn lights stopped working, transformer tested ok. What could be the problem?
You checked that power pack is getting electricity.
If a bulb burns out, and is not replaced, additional power can burn out other bulbs.
Nov 14, 2010 | Intermatic Malibu 300W Power Pack...
The lights stay on all the time and won't shut off. The front ones work fine but not the back lights. Any idea's? thanks,
Unfortunately when the power pack stops working there is no solution.
Your power pack has electricity so that is not the problem.
The bulbs turn on, so the bulbs are ok.
That means the power pack has malfunctioned, and needs to be replaced.
I did find some tips to help folks preserve their power packs:
Nov 12, 2010 | Intermatic Malibu 121W Power Pack...
My timer is running and I have swapped the black and red pins to turn on and off the lights but the lights do not come on? Were do I find the model number?
My model number is on a sticker inside the door.
I have the 300 watt, and it matches the total wattage of my bulbs.
A lot of people ask for replacement Malibu tripper pins on Fixya, so your tripper pins might be worn down. I cannot find Malibu trippers, even on e-bay. And the new timer clocks are electronic.
Check your circuit breaker to see if unit is getting electricity, including GFCIs in bathroom.
Plug hair dryer in same plug as Malibu to see if there is power
Brush a wire across the screw terminals to see if there is any spark going to bulbs.
It's unlikely that all the bubs failed at once, but if power pack shows spark on the terminals, the bulbs should be getting electricity.
If a couple bulbs burned out, the power pack can burn out the others.
Unplug power pack until you get bulbs replaced.
Unfortunately if the power pack stops operating, it is broken.
Nov 11, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Where can I find wiring and set up instructions?
Below is link going to malibu.com manuals
http://www.malibulights.com/customer_service/owners_manuals.aspx
Below is link going to a guide for setting up your malibu lighting
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack.aspx
Let me save you some money:
1) Match up wattage of bulbs with wattage of power pack:
15 - 20 watt bulbs = 300 watts = 300 watt power pack ... if you buy the 500 watt power pack for 300Watts of bulbs, then it will burn up the power pack.
2) Replace bulbs as soon as they burn out or other bulbs will burn out and the power pack will burn out too
3) When working on bulbs, unplug power pack or the power pack may burn out
If you need more assistance, add a comment and I will answer
Nov 01, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
Timer on my 200W transformer is working but lights will not turn on manually or by timer. when i turn on with manual switch they flash on for a second then turn off. i am just under 200W for total...
You posted under Intermatic-malibu power packs.
Wattage of bulbs must match wattage of power pack or bulbs and power pack will burn out.
Your power pack might be damaged beyond repair.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Aug 23, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Have a low volt intermatic transformer where only one side works.
If you have 2 sets of A and B terminals, then power pack is usually rated for 600 watts, with 300Watts on each A and B.
I don't know how to tell what wattage power pack is, except add up total watt amount of bulbs that originally came with unit. That should give approximate value of power pack wattage.
Open following link for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Jvc vcr/dvd recoroder dr-mvis
No power, No Display - test voltages on secondary side of transformer were pulsating
Check diodes 6230, 6240, 6210. They are BYW98 Rectifiers, in my case it was s/c. Thanks to Sparky for similar tip - Philips CD Model: CDR770/00
No power and no output
Replace C6 with 4.7uF, 250v
No power, voltages on secondary side of chopper were very low and pulsating
Check diode 6230. It's a BYW98, in my case it was s/c. Note: it's the rectifier for the 14v line
Dead, no power up on pin 2 of ic601
Replace x601 on main processor ic601
(Brko) Toshiba DVD Model: SD-1750 / SD-2800
No sound
Replaced C927 / C928
Nov 26, 2007 | Audio Players & Recorders
Hardware & Accessories Logo
156 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
