Question about Kenmore Refrigerators
Hello, i need main bracket dispenser front door for Kenmore 106.57943700 Coldspot
Posted by AF Contractors PR on
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kenmore Master
  • 36,371 Answers
Try sears. we dont sell parts
Posted on Apr 16, 2019
5 Related Answers
Michael Anderson
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
Posted on Apr 30, 2008
Anonymous
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
cj2176
Chris Jones
  • 520 Answers
SOURCE: Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Posted on Aug 18, 2010
Oloyede Monsuru
  • 1417 Answers
SOURCE: How do I replace the
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Posted on Jan 16, 2011
mario3246
Mario3
  • 56 Answers
SOURCE: Kenmore Coldspot 106 door needs aligning not closing properly
Try to search for the solution within the manual: Kenmore Coldspot Model 106 Manual
Posted on Nov 17, 2013
Kenmore coldspot refrigerator model 52552100 makes ice but wont dispense it
Below is a fix by another owner of your make and model for the same issue.
Pulled out ice bucket; tried ice dispenser with door latch pressed in and solenoid engaged and motor moved. Tried again and nothing (couple of times). Tried water...all good...good closure of dispensor flap (air pot operated). Opened dispenser (pried off carefully from bottom on this unit not to take off the glued part) and saw the micro-switch broken off of the ice dispenser side. Checked micro-switch (all good). Replaced control bracket...all good to go.
Nov 25, 2016 | Kenmore Refrigerators
Replace dooor handle side by side kenmore coldspot 10656833602
There is a cover on the handle. Remove with a screwdriver by gently prying...careful not to break the plastic clips. Once removed, unscrew the main handle & replace.
Dec 17, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
I need the housing for my ice/water dispenser Kenmore Coldspot 106.56926600
Part Number: 8201756
http://www.applianceblog.com/mainforums/sears-kenmore/16912-kenmore-dispenser-housing-broken.html
Jun 11, 2012 | Kenmore Refrigerators
Kenmore coldspot 10656929600 ice dispenser flap
probably will have to take dispensor apart to see what the problem is there, front cover should pry off from bottom
Jul 07, 2009 | Refrigerators
Not dispensing water
more likely the switch braket has broken. this unit has a bracket that holds the micro switches on small plastic pins and they break easily. you didnt list a model number but you an secure the part thru partsdirect.com and here are the steps for repairing the unit:
  • first unplug unit
  • remove disp cover, look on bottom edge of the cover and you will see 2 slots for a flat tip srew driver carefully pry the cover off
  • you will expose the switch bracket and most likely will see the broken pins.
  • just change the switches and light socket over to the new bracket (dont forget to install the switch spacers)
some models have 2 screws under the drip tray as opposed to having to pry the cover off.
If this doesnt sound like your refrig post a complete model number and I will get you the proper instructions. thanks peyton
Mar 16, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore refrigerator
1. Remove the switch cap and unsnap the two (2) tabs at the bottom of the front cover from the
housing first. Pull the bottom out and lift and the front cover from the housing. (Fig. 27)
2. Remove the two (2) hex-head screws securing the metal control panel cover to the dispenser
housing. This will also free the control bracket from the housing although it will remain tethered
to the freezer door by the wiring harness. (Fig. 28)
3. Disconnect the wiring harness connectors from the terminals
on the switches and light fixture in the control bracket.
Removing the Dispenser Assembly
1. Do the previous three procedures.
2. Remove the eight (8) hex-head screws securing
the dispenser housing to the freezer door. (Fig. 29)
3. Carefully pull the housing from the door.
4. Pull the water supply tube from the top of the dispenser housing.
5. Pull the wiring harness leads from the dispenser housing.
6. Disconnect the wiring harness connectors to the electric
foil heater that should get you in there
Feb 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
115 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
