Computers & Internet Logo
Question about Seagate Computers & Internet
Plugging older seagate into newer laptop for first time. light doesnt come on, doesnt recognize seagate, need help?
Posted by Trish May on
2 Related Answers
Anonymous
SOURCE: power light flashes but disc doent spin
no hablo ingles
Posted on Apr 28, 2010
Anonymous
  • 161 Answers
SOURCE: I can connect one newer macpro laptop, but not new
If it was working before. unplug the power to the router and plug back it.
Posted on Dec 23, 2010
Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
1helpful
My seagate freeagent go 500mb cannot be recognized by my laptop. using sea tools windows scanning for supported drives is taking such a long time as the ext drive cannot be detected by the laptop.
Have you got any drivers installed for Free Agent? If you have an older OS you will need to insert a system disc for the Drive, or else it won't recognise it.
My hard disk drive does not respond or show up in My computer when plugged in.Its a seagate 1 tb with those lights in front which usually light up when connected but even that doesnt happen when i plug it...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance. Thanks for using FixYa
After Seagate device not recognized, all flash drives gave troubl
even tho you have AV software installed , I wouldn't write it off so easily. Download and run Malwarebytes from
www.malwarebytes.org
and you may be surprised how ineffective AV software can be some times.
Don't forget to rate the advice!
http://www.aa1consulting.com
1helpful
Usb device not recognized
try connecting your phone to a USB 2.0 port.
Some older computers give this error. If you can find a newer laptop to try and plug it in it may recognize it. As far as a driver goes, with Windows XP or Vista you shouldn't need a driver disk at all. It is more like a compatibility issue than a software problem.
Feb 27, 2009 • Cell Phones
My laptop doesn't detect the external hard drive
Hi there
hey if you are not getting it to recognizing the drive on system startup use your set up disk if you have it if not go to device manager and scan for hardware change and see if it can be found there if not try going into the bios and ensure that the usb ports are enabled and that the plug and play is enabled also you also need to ensure that the device is compatable with your pc i would check with the manufacture of the computer best regards mike
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Hard drive not being recognized
dear ramroot
enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
restart your computer.
trying to connect your ext. Harddisk again
oke
cropp
Top Seagate Computers & Internet Experts
Steve
Marvin
Marvin
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
