Question about Watches
Replacement battery for Lucien Picard Queen Pacifica 2803BKD
Posted by Patti Allen on
I received a lucien piccard vd53 watch and can't get it to run.What do I do to start it??
I see your watch has a Seiko VD53 Quartz Chronograph Movement. Several possibilities come to mind - the watch may have a small plastic spacer under the crown which is there to stop the battery running flat before the watch is sold. If that's the case then simply remove the spacer and press the crown in. Possibly, the battery is flat and will need replacing, or you've received a faulty watch - either way (and I interpret your using the word 'received' as meaning that it was a gift to you) you should tactfully point this out to the giver. They wouldn't want to have wasted their money, and hopefully they've kept the receipt.
Nov 13, 2017 | Lucien Piccard Watches
I have a lucien piccard watch, purchased probably in the 70's. Would it be water resistant?
Yes, I think that your Lucien Piccard Watch is water resistant until now as long that the gasket of the caseback is still intact. and for you to find out that the gasket of your watch is still intact then, you should bring your watch to the expert to check your watch gasket. i hope i solve your problem.
Jul 09, 2011 | Lucien Piccard Watches
Changed power cell and watch still not running
Movements become "dry" over time and must be serviced.
Another common problem we see is that there is oil or battery acid (from a previously leaking battery) inhibiting proper connection between the contacts and the battery.
The quartz and the circuit itself may also go bad on a movement at any time.
If it is under warranty, you may send it back directly to Lucien Piccard.
I recommend you visit your local Certified Master Horologist for what is usually a free diagnostic. They can test the battery, the connection, the movement, and usually repair, service, or replace the movement for you. They will also generally give a free estimate.
Feb 23, 2011 | Lucien Piccard 26321 Wrist Watch
Looking for a leather band for a lucien piccard
i only found some for women sorry !!! http://www.newegg.com/Product/Product.aspx?Item=9SIA01C0001NU2&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Watches-_-Lucien+Piccard-_-9SIA01C0001NU2
Nov 09, 2010 | Lucien Piccard 26024 Wrist Watch
I have a 26022D and the band is broken and not repairable. Where
mcdevito75 here, Depends on what you want to replace, BEST BET, look for a small watch repair shop in your area for replacement.
Jul 10, 2010 | Lucien Piccard 26024 Wrist Watch
Replacing Batteries on Sealed Watches
Who ever told you that story about throwing it away should not be in the business of repairing watches. I have the same problem and googled Lucienpiccardusa.com. They do lifetime battery replacement and some general servicing according to your warrenty. From what I read on their web site you only pay for the shipping charges.
Hope this helps you. JFG
Dec 24, 2008 | Watches
Need New Watch Band
i have repaired watches like this before. I advised u to go to www.the watchery.com and www.lucienpiccardusa.com or www.ebay.com. there u can buy and choose branded lucien piccard watch band.let me know if u see what u wanted...
Jun 14, 2008 | Lucien Piccard Watches
Watches Logo
130 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
