Question about Westclox Audio Players & Recorders
Sorry to say that clock repair is not easy and is a lost art. You may want to see if you can locate one locally that can fix it. The only other chance you have is to open the clock and look for the winding spring and the pawl that holds it and release the tension by holding the pawl back as you put torque on the winding stem, then release the stem slowly and then release the pawl.
Posted on Apr 16, 2019
SOURCE: Westclox Monarch Alarm Clock - Model No. 90003
While holding down the snooze bar that says "ALARM" on it, hold down either of the "HOUR" button to set the hour when the alarm should go off or hold down the "MINUTE" button to adjust the minutes for when the alarm should go off. Switch the "ALARM" to "ON" when done.
Posted on Sep 03, 2008
SOURCE: Design of back of clock
I know how you feel... it is hell to get old. Have you tried looking at second hand stores for the old original Big Ben? I changed over to electronic digital alarms with battery backup, but I'm with you... it is not the same. It is a good thing that time becomes less critical to us as we age... except having more of it. Perhaps you can go to Westclox website and click on CONTACT, and send them a message yourself. Better in your own words than mine.
http://www.alarmclocksonline.com/BigBens.htm
May God richly bless you.
Posted on Oct 24, 2009
Testimonial: "Thank you for the info about contacting & getting my concerns to the Big Ben guys..."
SOURCE: I have a westclox atomic alarm clock - model #700...
I have the same alarm clock the damn thing gives me a heart attack when I wake up. All in all I have the instructions for your clock.
Simple on the back of the device there are five buttons hold down the one that is labeled mode/set then the display will flash use the oC|oF/Up key or Wave/Down key to change the keys and the mode/set the to move between each field.
If you press (not hold) the Mode/Set key you can change the alarm, change the numbers using the degreeC|DegreeF/Up or Wave/Down key to change numbers accordingly.
To turn the alram and snooze function on or off press the Alarm/on\off key.
What I just said may sound complicated but of you press the buttons as I told you then you should have no problems what so ever.
Posted on Jun 03, 2010
SOURCE: Westclox model 22717
Wesclox 22717 reset problem
Searched the web but couldn't find the answer either. I was about to throw the clock away when my 10 year old son came by and said "press hard". So that's the answer! I used a pen to press the time button then hit the hour and minute and it did the reset. Good luck.
Posted on Sep 23, 2011
The later alarm trip assemblies - the one in which the cam on the trip staff is a steel disc with a cutout, and the trip wheel is steel with a stamped out projection - can be troublesome. I had so much trouble with these parts on a 1970 Big Ben leg model reproduction that I replaced them with the old style trip assembly having the brass finger on the trip staff and a brass trip wheel. This solved the problem of the trip staff being carried around with the trip wheel.
