Question about Hyundai Televison & Video
Are the electronics of the touch screen on the dashboard in any way associated with the back of the vehicle? Can a rear collision make the touch screen go dim or dark in a 2018 Hyundai Sonata SEL?
Touch screen is dim/dark, letters jumbled up. Not enough light to see anything on it. Happened 3 weeks after a rear collision; but not immediately after. Can this be related?
Posted by Jason Calabrese on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: installing electronic transformer with 3 way touch dimmer switch
Consider using a MAELV-600 and a MA-R. The MAELV is rated for 600W Electronic Low-Voltage. The MAELV will require a neutral wire connection.
www.lutron.com/maestro
Posted on Oct 17, 2008
darin brown
  • 393 Answers
SOURCE: replacing rear wheel bearings on 1999 hyundai sonata
  1. for drum brakes with sealed hub(all one piece) remove lug nuts and wheel.
  2. spray penetrating oil around studs if there is a big phillips head screw visible remove it with impact driver/if not use big ballpeen hammer ,tap on flat of drum near studs(becareful not to hit them) until drum loosens(your creating a shockwave to loosen rust)
  3. once drum is off there are 4-bolts coming in from behind backing plate, remove them then hub should be able to be removed w/a little persuation from hammer.
with out sealed hub ,
  1. remove wheel
  2. remove dust cap,cotterpin,star washer(if equipped) do not re use cotter pin
  3. remove nut then washer, wiggle brake drum and front bearing will come out.
  4. put nut on shaft tighten 2-3 turns grab drum by sides and pull towards you this should remove drum leaving inner bearing/seal on shaft
  5. to replace reverse procedure making sure to pack new bearings w/grease(take drum and use long punch to remove bearing races, use race/seal installer to install new races
with disk brakes
  1. remove wheel
  2. remove caliper/bracket
  3. remove rotor
  4. remove 4-bolts from behind,tap old hub out
  5. reverse procedure
Posted on Nov 15, 2008
csmock132
Clint Smock
  • 4669 Answers
SOURCE: blinking light on center of the dashboard on Hyundai Sonata
That is your security light, It tells you the security system is active.
Posted on Apr 01, 2009
SOURCE: Dark Screen even when i adjust the 'brightness' tab?
check the power settings on te unit, if it is set to default for the backlight, possible that your LCD's backlight is not powering up properly on the unit or LCD's backlight needs replacement.
Posted on Jun 04, 2010
Anonymous
  • 15 Answers
SOURCE: My Nokia N8 touch screen has frozen, the other
if your have warranty on the phone please bring it back to the store where it was purchase bcoz if the touch screen is messed up there is no way for the phone to work properly
Posted on Mar 29, 2011
WHAT ARE THE IR,BRAKE-IN,BACK CON, WIRES FOR LITB100-7G RADIO
Automotive vehicles are increasingly being equipped with collision avoidance and warning systems for predicting the potential collision with an external object, such as another vehicle or a pedestrian. Upon detecting a potential collision, such systems typically initiate an action to avoid the collision and/or provide a warning to the vehicle operator. The aim is to design and develop a control system based on an automatic, intelligent and electronically controlled automotive braking system for automobiles is called as "INTELLIGET BRAKING SYSTEM". This Braking system consists of IR transmitter and receiver circuit and the vehicle. The IR sensor is used to detect the obstacle. There is any obstacle in the path, the IR sensor senses the obstacle and giving the control signal to the microcontroller, which in turn sends a signal to the motor to stop and also to the solenoid so as to stop the vehicle as programmed. This project facilitates electromagnetic braking system using solenoid. Here in fabrication module include a circular disc associated with a dc motor and a solenoid. Embedded system module includes micro controller with a solenoid and sensor
Dec 17, 2016 | Ford Cars & Trucks
Where is the Inertia switch
The switch shown to the right is intended to disable an electric fuel pump in automotive applications. This functionality is required in some vehicle racing applications, since an electric fuel pump may otherwise continue operating after a collision orrollover. If the fuel line is broken or the vehicle is inverted, fuel may be spilled, creating a fire hazard. A small loose weight (called a proof mass) is trapped within a spring-loaded cage. A shock in any direction will cause movement of the mass relative to the cage. If sufficiently shocked, the cage will spring open which actuates an associated switch. The switch is reset by pressing the cage closed through the flexible (red) top cover, retrapping the mass. These switches are also used to open a contactor (a large relay) to disable the high power circuit of a battery electric vehicle upon collision.
Mar 26, 2016 | Cars & Trucks
Why wont my exonic touch screen not working?
It could be a number of things. The touch screen could be broken, Has it got a clearfilm cover on it? like you get on cell fone screens,
Aug 05, 2014 | EXD 7095 7 Touch Screen In-Dash Multimedia...
How do the Volvo safety coefficient is so high?
Safest Volvo so has the following main factors: the first is the reasonable structure, the maximum to prevent collision to the personnel inside the vehicle damage, sometimes for the sake of security structure tend to give upmore gorgeous appearance; and the choice of materials, at the time of the collision can absorb a large amount of energy, the purpose is to protect thepersonnel inside the vehicle safety auxiliary facilities. In addition the college entrance examination, such as chairs, and airbag reset tool, are the precision of the electronic system of strict control.
Can be said Volvo's safety is omni-directional, for them, not what is more important than safety.
Dec 06, 2013 | Volvo Cars & Trucks
How to replace headlight switch
First check all the light bulb's. Then check all the fuse's related to the lights on the vehicle. If that doe's not solve the problem, Check the relay that may be associated with the exterior rear light's. If that does not solve the problem, You either have a bad light switch itself located under the light knob that you are turning the lights on and off with, which is located on the dashboard display panel in various different location's depending on the make, model and year of your motor vehicle. and if that does not solve your problem it is possibly a wiring shortage which is followed from the light switch through the dashboard, to the fuse box, then through the entire vehicle running from the front of the vehicle to the back of the vehicle on the floor of the vehicle on either side of the vehicle, or the wire's may be located in the interior roof trim located on the inside of the vehicle over the door area running from the front off the vehicle to the rear of the vehicle, or the wire's could also run from the front of the vehicle to the back of the vehicle through the center of the floor or center console area, But most light shortage's are located either at the light fixture itself, which is where the light bulb is located, or either at the fuse in the fuse box, or at the light switch located on the dashboard display area.
Nov 30, 2012 | 1998 Lincoln Town Car
Brake light
Typical Jaguar Dealership attitude. You didn't have them repair the collision damage, and they are punishing you.
Great car, lousy dealer attitude.
Go to http://www.jaguarforums.com/forum/xj-x308-xj8-xjr-27/ and do a search. If no help found, join the forum and post this question.
Jun 11, 2012 | Jaguar Vehicle Parts & Accessories
Could Rear end damage from a wreck cause my speedometer and gas gauges to stop working?
You must understand that collision stresses the ENTIRE vehicle. Just because it was hit from behind, does not mean that there is not collision damage in the front. I had a vehicle in my shop several years ago that was hit from the rear. The engine began knocking shortly after. It turned out that the collision had jarred the engine hard enough to cause the crankshaft to crack. This type of damage is extremely rare, but can happen. Trying to convince the insurance company that this was collision damage was a real trick.... On the other hand, fuel sending unit failures are quite common (without any collision) and can cause your fuel gauge to stop working.
The only way to determine if your problems are caused by the collision would be to first diagnose the problem. Only then can it be determined if the current failure is caused by collision or possibly caused by a more commonly known failure type.
Dec 15, 2011 | 2009 Chevrolet Malibu
I have a 2000 eclipse....i just put in one of those touch screen cd players with a 7 in screen....now it kinda sounds like **** because i think the dashboard speaker went...can i just buy door and back...
yes. You don't need the dash speakers, you can just put door and rear speakers in. Also for the front you can get component speakers and put the tweeters in the dash. Trust me, it will sound great! Make sure whoever is doing this knows what their doing because another thing that can cause your system to sound bad is phase and polarity problems.
Sep 03, 2009 | Dual Dash Speakers 3" Cone Car Speaker
Unfindable object sliding back and forth in rear of vehicle.
Look INSIDE the bumper/apron. You will find that you really did more damage than you thought.
Mar 19, 2009 | 2002 Mercury Villager
Odometer,speedometer,etc. (not the lights) goes out on dashboard
Here are the Recalls for your Model Car. Nissan Altima Recalls Recall ID # 07E087000 - EXTERIOR LIGHTING:HEADLIGHTS Recall Date: OCT 25, 2007 Component: EXTERIOR LIGHTING:HEADLIGHTS Model Affected: ALTIMA Units Affected: 4654 Recall Details Recall Date:OCT 25, 2007
Model Affected:2006 NISSAN ALTIMA
Summary:CERTAIN TYC HALOGEN TYPE HEADLAMP ASSEMBLIES P/N 20-6644-00 SOLD AS AFTERMARKET EQUIPMENT FOR 2005-2006 NISSAN ALTIMA PASSENGER VEHICLES. THE PHOTOMETRIC WERE MISALIGNED WHICH DOES NOT COMPLY WITH FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.
Consequence:MISALIGNMENT OF THE LIGHTS DIMINISHES FRONTAL ILLUMINATION WHICH COULD RESULT IN A VEHICLE CRASH.
Remedy:GENERA WILL NOTIFY OWNERS AND OFFER TO REPURCHASE THE NONCOMPLIANT LAMPS. THE RECALL BEGAN ON OCTOBER 25, 2007. OWNERS CAN CONTACT GENERA AT 714-522-6688.
Units Affected:4654
Notes:GENERA CORPORATION Recall ID # 06V223000 - ENGINE AND ENGINE COOLING Recall Date: JUN 21, 2006 Component: ENGINE AND ENGINE COOLING Model Affected: ALTIMA Units Affected: 85000 Recall Details Recall Date:JUN 21, 2006
Summary:CERTAIN PASSENGER VEHICLES EQUIPPED WITH 2.5L ENGINES MAY EXPERIENCE EXCESSIVE ENGINE OIL CONSUMPTION AS A RESULT OF IMPROPER PERFORMANCE OF THE PISTON RINGS.
Consequence:IF THE OIL IS NOT MAINTAINED AT LEAST AT THE MINIMUM LEVEL, ENGINE DAMAGE CAN OCCUR AND IN EXTREME CASES RESULT IN AN ENGINE FIRE.
Remedy:DEALERS WILL REPROGRAM THE ELECTRONIC CONTROL MODULE (ECM OR ENGINE COMPUTER). YOUR VEHICLE WILL ALSO BE INSPECTED TO DETERMINE IF IT HAS BEEN CONSUMING ENGINE OIL AT A HIGHER THAN NORMAL RATE. IN A SMALL PERCENTAGE OF VEHICLES, ENGINE REPLACEMENT WILL BE NEEDED. ON JUNE 9, 2006, NISSAN NOTIFIED OWNERS OF THE POSSIBILITY OF EXCESSIVE OIL CONSUMPTION AND THE IMPORTANCE OF MAINTAINING THE OIL AT A PROPER LEVEL. FOLLOW-UP LETTER TO OWNERS ADVISING THEM OF THE STATUS OF THE RECALL WAS SENT DURING AUGUST 2006. FOLLOWUP LETTER TO OWNERS WAS SENT ON NOVEMBER 15, 2006. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Units Affected:85000
Notes:NISSAN NORTH AMERICA, INC. Recall ID # 06V046000 - SUSPENSION:REAR Recall Date: FEB 13, 2006 Component: SUSPENSION:REAR Model Affected: ALTIMA Units Affected: 759 Recall Details Recall Date:FEB 13, 2006
Summary:ON CERTAIN VEHICLES, THE REAR SUBFRAME MAY HAVE BEEN MANUFACTURED INCORRECTLY, WHICH COULD RESULT IN A CRACK IN A BRACKET WHICH HOLDS PART OF THE REAR SUSPENSION.
Consequence:IF THE BRACKET IS CRACKED, THE STABILITY OF THE VEHICLE MAY BE AFFECTED UNDER SEVERE DRIVING CONDITIONS. THIS COULD LEAD TO A LOSS OF CONTROL OF THE VEHICLE WHICH COULD RESULT IN A CRASH.
Remedy:DEALERS WILL INSPECT THE REAR SUBFRAME TO DETERMINE IF IT WAS MANUFACTURED INCORRECTLY AND REPLACE IT, IF NECESSARY. THE RECALL BEGAN ON FEBRUARY 27, 2006. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Units Affected:759
Notes:NISSAN NORTH AMERICA, INC. PB016 Recall ID # 07V527000 - ENGINE AND ENGINE COOLING Recall Date: NOV 14, 2007 Component: ENGINE AND ENGINE COOLING Model Affected: ALTIMA Units Affected: 653910 Recall Details
Jan 03, 2009 | 2006 Nissan Altima
Televison & Video Logo
37 people viewed this question
Top Hyundai Televison & Video Experts
Marvin
Marvin
WATCHING YOU
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
