Question about Cycling
Replacement spokes for rear wheel speedcart v1
Posted by jay dick on
5 Related Answers
Anonymous
  • 292 Answers
SOURCE: spokes on back wheel detached
you need to take the wheel to a shop who re-builds wheels, the tire has to come off and new spokes fitted then they have to TRUE the wheel to make sure it is not buckled then re-fit the tire. not something you should really be doing yourself. if i am right in thinking you are in the UK then buy a copy of Motorcycle News, you should be able to find a wheel builder in there. i only know of 1 place ALF HAGON they mainly do shocks but i had a wheel straightened there years ago when i lived there. i think they are in Woodford ESSEX.
Posted on Mar 30, 2009
Anonymous
SOURCE: We own an older model valco pram with spoked
A bike shop can cut you replacement spokes to fit the size of your stroller wheel. In Canada that's about $30/spoke. Bike shops also sell you replacement tubes and tires for your stroller.
Posted on Aug 30, 2010
Anonymous
  • 83 Answers
SOURCE: I have a pair of
the rear spokes are the same size( yes ).
Posted on Feb 24, 2011
Testimonial: "Thanks muchos. That fixes my problem. "
JIm McCrosky
  • 59 Answers
SOURCE: Broken spoke in rear wheel. What could have caused
I ride a Trek 6.9 and have had spokes break for no apparent reason. Most of the time the spoke will break from over tightening on initial installation or just plain fatigue. Replacing the spoke is fairly straight forward. Remove the wheel from the bike and remove the tire. Remove the protective tape on the inside of the wheel to gain access to the spoke nut. After replacing the spoke you must make sure the wheel is true. If you do not have a set up for this, reassemble the wheel with the new spoke and take the assembly to your nearest bike store. They should have the equipment to true up your wheel assembly
Posted on May 31, 2011
Testimonial: "Thanks for the sensible advice - will get it sorted"
al_kupchella
Al Kupchella
  • 843 Answers
SOURCE: What is the proper tool to remove rear wheel
You need a freewheel/cassette removal tool. Here's a link to Park Tools page (great quality tools at reasonable prices) http://www.parktool.com/category/freewheel-cassette There are several different types to fit different styles. My usual method is to remove the quick release skewer, place the tool on the freewheel/cassette, put the skewer back on to hold the tool in place (skewer should be just a little loose). Put the tool side of the wheel down and clamp it in a vise. Then grab the wheel with your hands and twist it sharply (not slow and steady) counter-clockwise. Good luck, Vote if you found this helpful. Al K
Posted on Jun 08, 2011
Where can I buy replacement spokes for an SRAM S30 sprint rear wheel?
You could Google that. "SRAM S30 sprint rear wheel spokes" or call a shop that sells SRAM wheels.
Aug 31, 2011 | Cycling
Broken spoke in rear wheel. What could have caused it and is a replacement simple?
May 31, 2011 | Dahon 7 Speed Folding Bike
I bought a Huffy sea star 20 inch bicycle last year, the rear wheel keeps puncturing the inner tube, a spoke has come loose and the wheel wobbles. can't find a replacement wheel. Help!!!!!
Don't replace the wheel, get it fixed. The spoke can be tightened and the rim tensioned and trued. The rim strip probably needs to be looked at for exposing the spoke ends to the tube.
Mar 27, 2011 | Huffy Cycling
A spoke on the rear wheel has snapped off how can I repair it?
Simply buy a replacement spoke. Unscrew the dustcap on the tyre valve and deflate the tyres inner tube. Remove tyre using tyre levers(as you do to repair a puncture). Next remove the inner tube to reveal the spoke tensioners. undo the tension nut and allow the broken spoke to fall out, feed the other part of the broken spoke out of the hub. feed the replacement spoke through the hub and into the hole on the wheel rim. Now screw on the tensioning nut to the spoke.Tighten up to the same tension as the other spokes. replace inner tube and tyre, then reinflate. Viola!
Jan 30, 2011 | Cycling
Motorcycle wheel
I m an MX rider and spokes must be done professionally. Once spoked locktight is used. Ive seen my friend break 7 ribs on a fall when the spokes he replaced collapsed on a jump. 2 months no riding and R1000 damage.
Sep 21, 2009 | Computers & Internet
Bicycle Rear Wheel Problem
Tighten the two pinion gear bolts that are holding the rear wheel, if the wheel is wobbling, then that is the problem.
If this does not fix the problem, you will probably better buy a new wheel, or replace the whole pinion gear and axis assembly, better to replace the wheel.
Oct 29, 2008 | Victory VegasLow 26 Men's Dual-Suspension...
Cycling Logo
166 people viewed this question
Top Cycling Experts
Marvin
Marvin
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Cycling Expert? Answer questions, earn points and help others
