My Vision e500i-a1 will only play in black and white . Ideas ?
Posted by George Padgett on
Ryan DiTonno
I have the same TV. My issue is if I hook a playstation 4 or Xbox one up to it, there is absolutely no color. My Xbox 360 works just fine on it though.
Posted on Nov 26, 2020
I have a Vizio E500i-A1. I have backlights and sound but no picture. I have ordered and replaced the tcon, main board and power supply board. Still no picture. Any Idea what the problem is?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 20, 2016 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
When I went outside, tv was working. When I came back in it was off.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 04, 2016 | Vizio Original Smart tv Qwerty dual side...
Vertical lines on tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 19, 2015 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
How to fix my led screen, it has no picture i have purchase and replace the led driver.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Command voltage to switch ON the LED driver section, should come from the main board's system control section. It do not come now.
Aug 07, 2015 | Vizio Smart TV keyboard remote control for...
How to I get a new remote sensor for Vizio E500i-A1
You can get it from most of the electronic spare part shops. It is an easy to get component, and won't cost more.
There are many types and numbers to it, and you should make sure about the type and number of remote sensor fitted with your TV; before buying a new one.
230cd4b5-0717-4f01-9745-3c3cbc3fe5f4.jpg 0367fd6b-ba2b-40bc-ada5-cecb13c6d5ff.jpg 9db40c93-ca8f-4f53-81b5-6499a167bff6.jpg a9ac5787-b6e7-4b07-b024-b50e24bc47d1.jpgThese are the examples.
The number can be located at its side.
google.com/+GopakumarGopalan
Aug 07, 2014 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
