SOURCE: my new hoover washing machine
Sorry but I do not know your particular machine so I am guessing BUT I would suggest as a first step that you check the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. My following general guidance notes should assist although not all of them will apply.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
SOURCE: My haier topload washing machine showing error e5
If you wish to get more details visit the sites linked here. http://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/
SOURCE: Hi everyone I have toshiba washing machine AW-SD160UBB show me E5 error, so what I have to do!
http://electrotechnician.blogspot.com/
https://electronicshelponline.blogspot.com/
Please visit these sites to get some details.
If no water enters drum it is because the water solenoid is not opening and admitting water. You may have to get new one. Check attached site for part and price. Tip
Once you have the part number it is not uncommon for you to enter it into ebay and get it for much less dinero! Search Over 2 1 Million Appliance Parts
SOURCE: e5 error in videocon topload washing machine drain system is allready cleaned
have you unplugged for a minute then repulsed to reset the EEPROM. (circuit board).?
hope this helps.
