If you wish to get some details about Treadmill repair and service also error codes and cause the check the following link.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
This can be interesting as there are a lot of bolts to disassemble. I tip mine up and lay it down in a pick up truck or a van you can take the seats out. They are very heavy so you need help.
bonjour, quand je fais partir mon tapis roulant il fonctionne pendant quelques seconde, ensuite le chiffre ( 3 ) s`affiche dans le coin gauche et il cesse de fonctionner, pourriez-vous m`aider? Merci
Error code seven is due to the console getting locked. I called Sportcraft and they said to do this: Unplug the treadmill for five min and then re-plug the treadmill. Now push the ON/OFF switch to ON and insert the safety key. Now press the MODE and STOP button simultaneously. Without releasing the buttons take out the safety key and insert it again. Now you should hear a beep and the display will come on. Release MODE & STOP and now press the Speed increment (+) button
