Question about Kenmore Refrigerators
Kenmore 596.9550890 side-by-side refrigerator - where is the water filter and what is the filter specification?
Posted by Chuck Munson on
john marconi
    New Friend:
  • 4 Answers
If you follow the water line then it should've been installed somewhere either under your sink or behind fridge cavity. If you can't find it maybe it wasn't installed. I tend to buy some off eBay in 5 packs. They tend to have the right specs for sale. Usually give them 6 months life each then they split. Its a cheap way to get good quality water. Good luck
Posted on Apr 15, 2019
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
Anonymous
SOURCE: Kenmore Refrigerator
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Posted on Feb 16, 2008
larryyb
Larry Youngblood
  • 291 Answers
SOURCE: Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Posted on Nov 26, 2008
Anonymous
SOURCE: Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Posted on Apr 16, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Kenmore side by side refrigerator water dirty
You may need to replace the water reservoir located behind the crisper. They are known to flake and cause the problem you describe. They are usually replaced with a coil of water line instead of one larger reservoir to stop the problem.
Posted on Oct 11, 2009
I have a Kenmore side-by-side ultrafresh refrigerator model # 5255210, serial# SM0649567. I cannot find the water filter. Where is the water filter located on this refrigerator ?
Owning 1 of these refrigerators will require you to replace the water filter from time to time, in order to keep the water fresh and the refrigerator running efficiently. Kenmore refrigerators are made by Amana, Frigidaire, GE, LG, and Whirlpool, so it is important to find out which manufacturer made your Kenmore refrigerator, in order to make sure you order the right part. Kenmore refrigerators use filters that are located in the bottom, front panel of the refrigerator. Details can be found on WiKi how to change a water filter on a Kenmore Refrigerator.
May 24, 2016 | Kenmore Refrigerators
Can't close the door on the water filter cabinet on my Kenmore Elite refrigerator
check to be sure you have the correct length filter in place, you may have one to long for the unit.
May 30, 2015 | Kenmore Refrigerators
Age of kenmore refrigerator, model 55061
Kenmore side-by-side Fridge Model 106-59522801 with ice and water filter, serial No. HRY 4657443
May 08, 2012 | Kenmore 22.0 cu. ft. Side-By-Side...
Change water filter
You'll find the manual at
www.managemylife.com/mmh/owner_manuals/4746/KENMORE-Side-by-Side-Refrigerator-L0307175
May 31, 2010 | Kenmore 57029 Side by Side Refrigerator
KENMORE SIDE BY SIDE REFRIGERATOR. QUESTION REF WATER FILTER
need to replace the filter every six months and yes you can get them at Sears but not Walmart
Nov 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Light bulb
Sounds like you got a defective bulb. Make sure it is for 120 volts or thereabouts....not 6 or 12.
Jun 19, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Leaking water and replace filter light not resetting after filter replacement
are you sure that the filter is installed corectly
remove the filter and reinstall it to be sure
May 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side dirty water
The original cap for the filter, was supposed to be a plug bypass, for application of outside undersink filter. Using, this, one can check to see if the filter was the contaminant here. You need to be, more specific, to explain a problem. Something is too too generasl,,, color, consistancy, odor, quantity, filter has a fine fine filtrationl unit on the outlet, and if defective the charcoal residue may come out. You can remove filer and pass suppy water thru and review the effluent coming out. ??? Regards, fmauka
Sep 19, 2007 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
133 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
Dale Copeland
Dale Copeland
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
