Question about Car Audio & Video
Player will not eject cd
Golf 2014, 6 cd changer
Posted by Stefanie Felix on
5 Related Answers
Anonymous
SOURCE: cd-changer Blaupunkt IDC-A09
The solution is to disconnect the head unit and the cd changer from each other and from the car itself, leave it for ten minutes. reconnect and turn the ignition on but not the car itself, enter radio code if has one and all should work.
Posted on Jan 03, 2007
Anonymous
  • 54 Answers
SOURCE: HU 850 CD stuck in player
One thing about Volvo CD player/changers...they tend to not like burned CDs and even more, burned CDs with labels on them.
I'd suggest against trying to get it out yourself.
You can get it replaced and the dealership should have a form so you can get your CDs sent back.
Posted on Aug 15, 2008
Anonymous
  • 73 Answers
SOURCE: cd changer won't play, load, or eject
Had the same problem on our 03 yukon (not the changer but the main head unit) - have a 3rd party waranty and they replaced it. You can get the part for less than 300$ and it's easy to install.
Posted on Aug 06, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: 6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Posted on Sep 30, 2009
dj_relly999
dj_relly999
  • 4070 Answers
SOURCE: cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
Posted on Feb 10, 2010
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
How do you eject the cd player in my 2014 equinox?
There should be little hole next to the slot insert a needle and it should reject
Oct 16, 2014 | 2014 Chevrolet Equinox
Cds will not eject in g35 bose stereo
The Cd player doesn't work get a new cd player...
May 28, 2012 | Boss Car Audio & Video
6 disc, will not eject or play cd's
Try tapping on the changer. Sometimes a gear gets stuck inside the changer and tapping on the changer frees the gear.
Feb 15, 2012 | Alpine CHM-S630 6-Disc CD Changer
Cd player saying reset 2, how do you fix that?
If its allowing you to eject the cd stack eject it unplug the unit and allow a 20 minutes.
Sep 22, 2010 | JVC CH-X350 12-Disc CD Changer
CHM-S630 6-Disc CD Changer: what is the best 6 disk cd player to connect to an...
hi how are you , my cd changer s630 recently just started to eject the whole cartreidge i push it back and its makes some nosies and then the same ejects it
May 18, 2010 | Alpine CHM-S630 6-Disc CD Changer
No ejection
hi does it make any noise or clicking?
you may have a cd dislodged or mag dammaged.
Mark
Sep 05, 2008 | Clarion DC625 6-Disc CD Changer
CD changer problem
had to replace player twice, luckily it was under warranty. FACTORY PLAYER JAMS EASILY !!! What I have learned is to put cd player in radio mode before ejecting instead skipping form disc to disc.
Jul 21, 2008 | 2003 Lincoln Navigator
CD NOT WORKING
IT MAY HELP IF YOU CAN REMOVE THE CD PLAYER AND THE POWER LEAD THEN REMOVE THE CD'S FROM IT (WITHOUT FORCING THEM) AND THEN RECONNECT THE POWER
Nov 06, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd-changer Blaupunkt IDC-A09
Sep 24, 2006 | Blaupunkt IDC-A09 5-Disc CD Changer
Car Audio & Video Logo
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
