Question about Samsonite Photography
SOURCE: my combination for samsonite suitcase no longer works what to do?
Is it locked shut?
Posted on Jun 22, 2009
SOURCE: I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Posted on Oct 17, 2009
SOURCE: How do I reset the combination lock on my
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
Posted on Mar 19, 2010
SOURCE: suitcase number locked combination forgotten
how can i open my forgotten combination samsonite suitcase
Posted on Oct 09, 2010
Aug 10, 2018 | Samsonite Photography
Mar 12, 2018 | Samsonite Photography
Dec 02, 2015 | Samsonite Photography
Dec 24, 2017 | Toys
Jun 14, 2013 | Luggage & Travel
Dec 28, 2010 | Samsonite Silhouette 11 Hardside Spinner
Nov 08, 2010 | Samsonite Silhouette 11 Hardside Spinner
Mar 19, 2010 | Locks & Locksmithing
Jun 16, 2009 | Samsonite Tripod
202 people viewed this question
