Your ERC(circuit board) through Sears is about $125.00. You can replace it yourself.
SOURCE: I have a 1/2 horsepower Craftsman Garage door
You apparently got a bad board. See if you can return it.
Testimonial: "Thank you that is what I suspected. I will exchange it."
SOURCE: Whirlpool AFB6640 freezer
Ive just revived one of these with similar symptoms that eventually died completley. A trawl of the internet shew that the most common fault is the SHRACK relay on the board. An Omron G5LE-14 relay is a better quality replacement at minimal cost. Its a ten minute job to replace it with a soldering iron. The RS part number is 369-488. However they are sniffy about dealing with non trade account holders by mail so if you dont have a trade counter nearby Rapid Electronics are a better bet (part number 60-4198). If you are really mean over postage there are also some ebayers offering the same part (e.g. lesjacksam) double check part numbers before going down that route though. Hope this helps somebody.
SOURCE: I am getting IO
The IO code is not even listed in the manual....
here is the manual
http://www.hayward-pool.com/pdf/manuals/Manual285.pdf
Towards the back of the manual there are troubleshooting and flow charts....they should help you to troubleshoot your heater....
before I would change out the ignition there are many other thigns to check out also...
heatman101
