Question about Janome Sewing Machines
Hi i have a janome artistic edge, and it won;t even turn on. I have tried different plugs and checked the cords nothing
Posted by LAURA CIACELLI on
1 Related Answer
SOURCE: My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Posted on Oct 15, 2012
My Janome 6500 keeps stitching even when I'm not pressing on the foot pedal.
Next time it does it try remove the foot control cord to see if it stops. If it stops then it will probably be the foot control. If it still continues to run, probable the main board in the machine.
Dec 27, 2017 | Janome Sewing Machines
Where can I get a manual for Janome Artistic Quilter SD quilting machine, please?
This might help: https://dealers.elna-usa.com/Documents/Janome%20Instruction%20Books/Inst%20book%20Artistic%20Quilter%20SD.pdf . However, it may not apply to your model. There are several Janome Artistic Quilter SD models that are listed during a Google search. (I found clear links about the model16, 18 and 26.)
I hope this helps. Some manuals are available through a sewing machine dealer for a slight fee; that may be a better option for you to find the exact manual for your machine.
Jan 18, 2017 | Janome Sewing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
My janome memory craft 6500 doesn't work turned on nothing happens replaced all cords
[PDF]Download Memory Craft 6500P Manual - Janome
janome.com/siteassets/support/manuals/.../inst-book-mc6500p-en.pdf
IMPORTANT SAFETY INSTRUCTIONS. When using an electrical appliance, basic safety precautions should always be followed, including the followings:.
Oct 15, 2015 | Janome Sewing Machines
Janome new home 691 Power cord and foot pedal
try checking a1sewingmachines.com and call them about the parts you need.
Jul 12, 2013 | Janome Sewing Machines
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
Janome 9000 lost all power in the middle of embroidery and won't turn back on.
have you checked to make sure the power cord is plugged into the machine correctly?
is the outlet getting electricity?
if the answer to the above is yes
then it's possible the power cord, motor could have with out
have you checked to see if the sewing machine has a battery compartment
or a fuse compartment?
Mar 29, 2012 | Janome Memory Craft 9000 Computerized...
I can't find my manuel or power cord for my Hello Kitty machine. How can I obtain one?
Hi
I can usually find manuals on Janome no problem but I can't access the one for Hello Kitty.
If you click on the specifications for any machine on the Janome site a PDF appears with a download manual button next to it. I can see the PDF but no download manual button.
http://www.janome.com/index.cfm/Machines/Sewing-Quilting/Hello_Kitty
This machine does look similar and I could get the link for a free manual, hope this helps. If not contact Janome.
http://www.janome.com/documents/File/ManualFile/3128.pdf
Try ebay for a power cord. A Janome cord should fit more than one machine. Just check the connection pins etc match.
Sep 07, 2010 | Janome Hello Kitty 11706 Mechanical Sewing...
Sewing Machines Logo
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
