Question about Saws
How do you use a somax 250 - Saws - Saws
Posted by Glenn Mainland on
Saw do not lift when turned over
Is this the saw you are talking about? A compound mitre saw?
TFO 250 Ryobi
I'm assuming you cannot lift the blade up by the handle without the whole saw coming with it. That usually means that the saw is locking into place for transportation purposes. Look at the pictures below and see if the lock pin in engaged.
Apr 19, 2015 | Ryobi Saws
Where can I find supplier of balance spring for Rusch HBS 250 band saw?
Check the website of Ads Precision Ltd. They are actually selling Rusch band saws. They're maybe selling parts of the saw. They should be able to help you. Check bandsawparts.com . They're selling aftermarket band saw parts of most types and brands of band saws.
Sep 09, 2013 | Saws
Where do I buy parts
i beleave target makes husqvarna try that 1st,if not try a tile store that sales saws,1st,try target tile saws i bet they will take care of you
Feb 25, 2011 | Husqvarna Tile Saw Tilematic Ts 250 X3...
Saw will not cut straight and destroys blades 250
I had the same problem. If you are cutting porcelain tile, it will not cut straight. The motor isn't fast enough.
These saws are made for stone cutting.
Jun 07, 2010 | Imer Tile Saw Combi 200va Portable Tile...
Made in USA push action with stop button print on switch LUCERNE USA 10212 250 V 16/8A saw around 10 years old
Same switch as used in Wen #6014 electric chain saw - anyone find a replacement
Oct 08, 2009 | Ryobi Saws
Where can I find a blade clamp for a STSE 250 jig saw, none of the local tool suppliers can help me
Go to an industrial supply store and purchase a shaft collar of the proper ID dimension
Jul 29, 2009 | Saws
I don't have the manual and don't know the gas ratio
If new it's 50:1 and after 100hr Break in you can use 40:1
If not under warranty most saws and 2-stroke engines work great @ 40:1 ratio
Some Old saws use 32:1 and some as little as 16:1
Stick with a 40 to 1 mix ratio for all newer 2 Cycle stuff you own and you'll be just fine!!!
Nov 20, 2008 | Garden
Saws Logo
144 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
