Question about Jet Health & Beauty
Just replaced the batteries in my Jet 3 Ultra. Why is there one light that is repeatly flaming?
Posted by Cyndi Holbert on
5 Related Answers
oregoon
  • 175 Answers
SOURCE: jet 3 ultra 3 Flashes The left motor has a short
Bad news; probably a short in the primary for the motor. This usually happens when the chair has been driven over unstable terrain, like wet, soggy grass and it bogs down in the muck. Driving it out while seated causes over-amping on the motors as they try to compensate for slipping, etc, and a motor will fry or a fuse will blow, or wiring harness will cook. You can replace the motor gear assembly for about $900.00, or try taking the motor to a rebuilder and have it rewound, which runs a couple hundred and the motor is like new again. Jack the left side up, remove the left wheel (make sure you save the key that fits in the slot on the axle! They get lost easy). unplug the motor and remove the 6 bolts holding the motor to the frame, disconnect the shift mechanism and the motor is free. separate the motor from the gear box and take the motor into the shop, reinstall and test run it. If the gearbox wasn't damaged, it should be good as new.
Good luck
Posted on Jan 08, 2010
Anonymous
  • 29 Answers
SOURCE: jet 3 ultra needs new battery, where do you get
you can get them from batteries plus. make sure you look at your current batteries and request the correct volts amps and size.
Posted on Mar 18, 2010
lennieg2000
  • 692 Answers
SOURCE: On my Ultra Jet 3
Count the number of flashes IE 3 flashes a pause then 3 flashes this is a error code and tells the tech what the problem is. Without knowing the number of flashes I cannot help. If you have your owners manual there should be a page for error codes somewhere near the joystick page
Posted on Aug 17, 2010
vetteman3002
Rodney Clark
  • 2299 Answers
SOURCE: I just replaced the batteries
Are you getting the same exact thing as before charging the batteries?
Posted on Oct 26, 2010
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Posted on Nov 25, 2010
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Aug 09, 2014 | Jet 3 Ultra Power Chair
Replace battery for the jet 3 ultra
\hmm what do u need to know? how to replace battery?if so take seat off then take off shroud and u will see batterys,make a wiring diagram of how batterys are conected before u remove them, good luck
Jan 20, 2014 | Jet 3 Ultra Power Chair
Control system trip on jet 3 ultra
A flashing lite is an indicator of a fault condition. Is it steady or flashing?
Nov 19, 2012 | Jet 3 Ultra Power Chair
We have an wheelchair but we don't know how to use it.How do we operate the controllers. We replaced the batteries. Could you help us?
Majority of wheelchairs are make by two companies.
Sunrise Medical and Jazzy
You posted Jet 3 Ultra on the title.....I'm including the instruction HERE
Aug 13, 2011 | Jet 3 Ultra Power Chair
Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
Feb 17, 2010 | Jet 3 Ultra Power Chair
Pride mobility Jet 3 Ultra Power Chair 7 flashing lights. joystick error. how do i fix ? Three red LEDs Four yellow LEDs
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
Sep 06, 2009 | Jet 3 Ultra Power Chair
The battery on my jet 3 will not charge
you need to replace both batteries, their called U1 batteries (35 AMP-Hour)
Jun 08, 2009 | Pride Mobility Products New Pride Mobility...
Batteries run low fast on jazzy jet 3, heard brakes might be failing or motor needs replaced after replacing batteries?
one battery was low,,,,not sure if anyting else is bad, used chair...by having only one battery low, it ran down the chair...
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Health & Beauty Logo
77 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
