Question about Saws
Capacitor wiring diagram for a craftsman model 113.241920 table saw.
Posted by Joe Rayman on
5 Related Answers
Bill Allen
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
RFJOINES2663
  • 4 Answers
SOURCE: wiring diagram for model 137.248830
SAME SAW I HAVE, I ASSUME YOU DONT HAVE THE ORIGINAL OWNERS MANUAL. GO TO SEARS.COM, AND TOWARDS THE TOP THERE IS A "PARTS" HEADER. CLICK ON IT AND ENTER MODEL NUMBER WHEN REQUESTED, THEY WILL ASK UP IF YOU ARE LOOKING FOR A SPECIFIC PART OR MANUAL . HOPE THIS HELPS
Posted on Apr 15, 2009
Anonymous
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: Table Saw Craftsman 113.299410 Manual
Here ya go...
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0060111.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 22, 2009
A Miller
  • 8404 Answers
SOURCE: i need the wiring diagram for my 10 table saw
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Posted on Nov 03, 2009
I found a Craftsman 9 inch table saw, Model 113.242720 and the capacitor was missing and switch was not wired up. I can't find a clear wire diagram for this anywhere. Do you know how to get one?
This is a very old tool, relatively speaking. View the owner's manual at https://www.manualslib.com/manual/495271/Craftsman-113-242720.html, but you're on your own for wiring. Your best bet would be to remove the motor and take it to an electric motor service center (check Google for a local motor shop) and have them set it up for you.
Dec 27, 2017 | Craftsman Saws
Wire diagram for craftsman 10" table saw
Hi there.
Prior to plug it try this.From your 3 prong grounded plug trace it up to your saw were you should have a black and a white from the same wire's end.Now the two whites are probably from the reset that you haven't replaced?Write back to let me know if this is right and I'll proceed.
Jul 25, 2013 | Craftsman 10" Table Saw
I have a Sears craftsman radial arm saw ( model # 113.197251) and the motor won't run. I replaced the capacitor and the motor just hums when you turn it on.
did you recently rewire this motor? If so recheck the wiring. If not sounds like you have a problem with the starter windings or switch in the motor itself.
Apr 21, 2011 | Craftsman 10" Table Saw
Need wiring diagram for a Craftsman Table Saw Model 113.298050
Keep your model number handy and have a look around here. If you can't find the identical model, you may find one of similar vintage with a wiring diagram that will suit your needs.
Otherwise, you may have some luck at the sears support site, at www.managemyhome.com, though I have had poor results finding them there.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 05, 2010 | Craftsman 10" Table Saw
Craftsman radial arm saw 113-197751 wiring diagram needed
A friend just inherited a model 113.197110 and we are in the process of trying to restore it. I can draw you the wiring connections if you haven't figured it out yet.
Apr 04, 2010 | Craftsman 10" Table Saw
Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Dec 03, 2009 | Craftsman Saws
I need the wiring diagram for my 10 table saw, I disconnected the motor and the power supp. without marking it first and now i don't know which wire goes where, please help!!
Nov 02, 2009 | Craftsman 10" Table Saw
I need a wiring diagram for a10" eletronic craftsman table saw model no.113.290 650C thanks
you might try Managemyhome.com and on page 11 of the manual is a wiring schematic for the motor. I don't know if that is all you need but the manual is 46 pages long.
Sep 17, 2009 | Craftsman Saws
I need to wire my Sears table saw 113298051...how?
Have a look at the manuals available here. Perhaps there' s one for your saw or a similar model with a wiring diagram you can use.
Good luck.
Aug 28, 2009 | Craftsman 10" Table Saw
Wiring diagram for model 137.248830
Mar 24, 2009 | Craftsman 10" Table Saw
Saws Logo
199 people viewed this question
Top Saws Experts
efs_perpends
efs_perpends
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
