Question about Toys
I need help with getting my collapsible quadrocopter 2.4ghz tuned and ready for flight as well as my self. came with 1 little manual which kinda explains a few things but hardly much.
Like how to take off underbody to examine and/or do i need to? are there batteries for copter? how to charge? do i need special batteries for control unit? how do i use camera? and on n on n on n on...
Posted by Charles Averill on
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: My battery isnt getting charged on my motorbike from engine
Hi and welcome to FixYa,
Almost always, your described problem indicates a charging issue. This points to the bike's battery not charging. Suspects would be:
  • voltage regulator (most likely);
  • connectors to voltage regulator (likely). Check/clean corrosion/burnt marks;
  • stator and/or the wires coming from it (least likely).
A CDI is a capacitive discharge ignition. This is an electronic module that fires the ignition coil.
Parts would depend on where you are. Often, other riders would provide information for parts source.
Good luck and thank you for using FixYa.
Posted on Feb 25, 2009
Anonymous
  • 55 Answers
SOURCE: My Blackberry Wont charge?!
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
hope this helps!
Posted on Jun 12, 2009
Anonymous
SOURCE: my copter will not charge
I just bought one for my Grandson and we had to plug in the outlet to the copter first, before pluging in the AC/DC adapter to the power charger. I know the instuctions do not explain it this way, but the green LED charging light would not come on and it would not charge doing it anyother way
Posted on Nov 01, 2010
Anonymous
SOURCE: right out of the box
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
Posted on Dec 28, 2010
bigguy810
robert DIBBLE
  • 448 Answers
SOURCE: FXD RC Helicopter - helicopter
check your controller some of them have a a.b.c switch for different channels look it over good
i have 5 rc helicopters i just bought the 3ft sky king and it has a a.b. switch on the helicopter
hope this helps you
bob
Posted on May 23, 2011
How to change flight mode from a 2 back to a 1 setting this affecting my flight control.
Push the "Fine-tune Strafe left/right" (located under the right joystick) towards the right and hold it in postion, then turn the controler ON.
May 02, 2015 | Protocol Manta 4-Channel Radio-Controlled...
When I drive it it won t catch up speed,and when I pull up to a light It jerk a little and when I get ready to pull off the car kinda slow then it slowly catc up speed.it burn a lot of gas.
Dirty air filter? Fuel filter? It could just need a tune up- new spark plugs, plug wires, distributor cap (if equipped) and rotor (the thing under the cap that sits on top of the distributor's center shaft).
Is your service engine soon light on while driving? That means there is a trouble code stored which may pinpoint the problem. Autozone and others do code scans for free-as long as the car is made after 1996. There may be a code even if the light is not on, so have it checked. Post back if your car is made before 1996, and I can help you with that.
Oct 04, 2014 | Cars & Trucks
I need to unlock my samsung flight 2 at HOME and i also don't know the password
That's kinda hard, dude. But have you try the superunlockcodes.com? Perhaps, that might be the possible solution to this charming phone of yours.
Mar 03, 2013 | Cell Phones
Bread rose really nice when baking but then suddenly collapsed?
you might need to use a little less yeast(maybe 1/8 tsp less) and probably a little more salt. bread collapsing can also be caused by not enough gluten so use bread flour not all purpose flour and/or add some wheat gluten to it. dough that is too wet can also lead to collapsed bread.
Sep 05, 2010 | Kitchen Appliances - Others
Phone is stuck in flight mode
are you saving the settings when choosing normal mode? rather than just exiting out when you have chosen the mode you want. as for the charging problem just go to a local corner shop or mobile retailer and get a new charger for it. this will probably help as sometimes the little pins inside the charging unit can become slightly bent.
Mar 09, 2010 | Sony Ericsson W910i Cellular Phone
How do you collapse the little tykes picnic table?
Flip over the picnic table and have a screw driver ready. There are 4 "braces" screwed into place to ensure the picnic table does not collapse on your children.
Once the braces are removed, you should be able to apply just a bit of pressure and fold the picnic table down flat.
Sep 29, 2009 | Little Tikes Fold and Store Picnic Table
GB5108 picture is collapsed to a blue line in the center
Go to Trinixsoft.com for complete manual. Cost 4.99 for download or 9.99 for shipped cd. I kinda have same problem but my exits with 3 red colors in bowtie form. I think mine is the TDA8351 or vertical control IC. Hope this helps.
Dec 10, 2007 | Apex Digital GB5108 51" Rear Projection...
Toys Logo
293 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
