Question about Proscan Televison & Video
So my proscan tv buttons are not working. Sometimes I can turn it on but the other buttons won't work at all. Any ideas please? Can't afford a new TV or expensive repair man, please help.
Posted by Janessa Pope on
5 Related Answers
Arpi
Arpad Kothai
  • 326 Answers
SOURCE: Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Posted on Apr 20, 2007
MikeNJ1964
Mike Longo
  • 398 Answers
SOURCE: my tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Posted on Aug 18, 2007
Vista Electronics
  • 1694 Answers
SOURCE: No power to TV
Make,model,month & yr built (off sticker on back of set) ??
Also,clarify symptom??
Changed fuse-was it bad??
Posted on Oct 24, 2007
Anonymous
SOURCE: ProScan Projection TV PS60690 shuts off
replace the small 5G5A125V fuse in the back where the power cord connects the to chip
Posted on Sep 02, 2008
Anonymous
  • 476 Answers
SOURCE: SONY KV-36HS500 will not turn
the light blinking six times indicates a probable horizontal circuit failure usually a shorted horiz out transistors but this is not the only component located in this circuit that could create this problem, sorry but i am affraid you'll need to get a tech to diagnose it to the component level or get another pc board to repair it. hope this helps some.
Posted on Aug 12, 2009
Testimonial: "This TV expert was on the money and clear with instructions. While I couldn't fix my TV, the advice was accurate and I will hire a pro to fix my set."
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
My tv. proscan mod. ps50700 won`t turn on
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
Our Proscan TV was working just fine then suddenly just lost power, there is power in the cord but the light won't turn on, is there a reeset button or fuse?
No the TV has failed. most likely the main PCB has failed or is shorted. To repair this will be close to the cost of a new TV at current prices.
Aug 19, 2016 | Proscan Televison & Video
Dish Network installed a new receiver (with the old receiver needed to be replaced). For the past 10 years that we have owned our ProScan....the dish has operated fine. Now with this new receiver, the...
Hi cjichel1830,my name is Mike Houston of DISH Network and I was going over your post and seewhere the new receiver won't auto-tune. With the new receiver if the remote hasnot been programmed to the new receiver and TV it will not work. I will giveyou this link http://www.dishnetwork.com/SupportSection/setup-receiver-totv,and it will help you with the setup of your new receiver and remote, if youhave any questions please e-mail me at [email protected]
Feb 08, 2011 | Proscan PS32700 32" TV
Remote not working
If this TV came with an universal remote, try pressing the TV key. Sometimes it works.
If that did not work any other RCA, GE, Proscan universal should work.
Feb 07, 2008 | Proscan 26LA30Q 26 in. LCD Television
Remote Code
The code 11178 worked for us for our Comcast remote.
Lauren
Jan 13, 2008 | Proscan 26LA30Q 26 in. LCD Television
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
123 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
