I need to find a service manual for an RCA F32650 so I can replace a blown flyback transformer, preferabley free if possible
  • bsjohnson Aug 07, 2009
    Thanks, that helps a great deal, already got the flyback but not the transister. I am an industrial electrician with 20yrs experience but am a rookie at television repair so I was hoping for a service manual and some schematics,got any ideas where to find any? The repair shop quoted me $250.00 just to repair the flyback, possibly more>>>>>
    Found it, Thanks, may have more questions but you have helped alot
    Top Expert:
  • 14,553 Answers
I have repaired many of these; if a high pitched buzz when you plug the set in---flyback and horz. output transistor are bad--transistor has a generic number on it--Flyback is location number LL05, part number should be 257805---you will find RCA no longer has this part--most now are replaced with an asti #2078----CHECK the RCA number on Ebay---company I get them from is Suburban Electronics---Flyback and transistor are less then 30 dollars for both.
Posted on Aug 07, 2009
  • SD Tech
    SD Tech Aug 07, 2009
    problem with RCA getting any schematic---check the horz output transistor for shorts--replace it and the flyback and you should be in business---the transistor is near the transformer on a heat sink.
I have a 1993 36 inch RCA, model # P46151WK. TV was on and suddenly heard something pop and it started to smell like something burned inside. It wont turn on anymore.
You may have a fried horizontal output transistor and a defective flyback transformer. If indeed this set is 17 years old.......cheaper to replace him...sorry!
Mar 01, 2010 | RCA F32650 32" TV
I have a RCA TV model F32650 Chassis ATC113CA1 and when i turn it on the green on light comes on and off 3 times then shuts off, i put a new fuse but it still does same on off 3 times, does anyone know...
I already figured out that my flyback transformer was bad, this is an ongoing problem with a lot of RCA CRT televisions because RCA used very cheap parts in order to save them more money, rather than making there customers happy with good quality parts, and my TV was made in MEXICO, and that my friends is why we the American people are getting screwed. (Shame on you RCA)
Jan 05, 2010 | RCA F32650 32" TV
My RCA F32650 turns on and has sound but no picture
You will have to take this in for service. The possibilities for your symptom are numerous - it could be flyback if the audio voltage is derived from the wall ac; it could be CRT; it could be video blanking (to protect the TV).
A technician need to check voltages to provide a suggested repair.
Nov 13, 2008 | RCA F32650 32" TV
RCA F32650 32" TV Problem:
The flyback is a a block with some wires coming from it. One of the wire is a big red wire that goes to the picture tube. The FBT is usually on the right rear of the circuit board.
Please be careful when working around the FBT as there are extremely high voltages present - in excess of 25K.
I would suggest you take it to a service shop as when the FBT goes, other parts are usually gone too.
Nov 03, 2008 | RCA F32650 32" TV
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
RCA(32 inch)
It is possible to repair it yourself. Let me caution you though. There are a number of generic manufacturers that sell replacement flyback transformers at less $$ than the original. The shop is most likety using the factory original which runs in the $75 range. Figuring on a typical labor rate of $125 for a 32" set gets you to the $200 figure. Realize also, that the $200 will include any other supportive parts that may be required in all probability as well as at least a 90 day guarantee.
Dan
May 29, 2008 | RCA F32650 32" TV
Rca hd52w59 convergence problem
there is a special fuse on the power deflection board. when blown this causes the processor to think it a crt tv. The fuse calle fl231 is a small brown rectangular fuse in the middle of 3 just like it next to the flyback transformer the big black thing with the large red wire comeing out. ussally it blows because the solder connections on the flyback. WARNING high voltages are generated by flyback. be careful please
Dec 27, 2007 | RCA HD52W59 HDTV Projection Television
Possible bad flyback transformer = RCA part # 257805......T.
Dec 10, 2007 | RCA F32650 32" TV
RCA TELEVISION
Heres the fix for your set, replace the following 2 parts:
1) flyback transformer RCA part number 257805
2) horizontal output transistor RCA part number 237470
you must be proficient at soldering & un-soldering or you can`t replace these yourself, be advised that the anode lead coming from the top of the flyback transformer can carry a VERY NASTY shock if not discharged properly before trying to remove it from the picture tube, I`d strongly advise you to call a tech unless your familiar with this type of repair, BMW Rider
Dec 09, 2007 | RCA F32650 32" TV
Proper grounding point for RCA F32650 TV
Leave set unplugged for a few hours = HV gone or discharge to CRT ground strap........................
Note: Part list.....257805 or ASTI 2078 xformer and
237470 horiz output xistor ( Do not use generic)
transistor must be first quality, no seconds ! !
Nov 25, 2007 | RCA F32650 32" TV
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
